Safety wire
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Safety wire
Post by Don ellis » Sun Oct 27, 2019 9:31 am
What is the most common size used on a model T?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Safety wire
Post by Humblej » Sun Oct 27, 2019 9:46 am
.032 and .051. I use the smaller wire for smaller applications and the larger wire for wishbone ball joint, flywheel bolts, differential bolts, and other larger bolts.
Aircraft safety wire pliers will make a professional twist for a nice clean job.
Many older posts regarding the best way to do safety wire.
Re: Safety wire
Post by Original Smith » Sun Oct 27, 2019 11:11 am
I ran out awhile back, and I had to go to three different auto parts stores to find it!
Don ellis
First Name: Don
Last Name: Ellis
Re: Safety wire
Post by Don ellis » Sun Oct 27, 2019 11:22 am
I tried that, they have no idea what I’m talking about. Amazon has it though.
First Name: Jeff
Last Name: Humble
Re: Safety wire
Post by Humblej » Sun Oct 27, 2019 12:20 pm
I get mine at Aircraft Spruce.
Re: Safety wire
Post by RajoRacer » Sun Oct 27, 2019 1:31 pm
I also procure my S.S. wire through the local aircraft parts store - iron "bailing wire" I p/u at Wilco Farm Store or Tractor Supply.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Safety wire
Post by D Stroud » Mon Oct 28, 2019 4:24 am
Harbor Freight has Stainless Steel safety wire very reasonable, not sure about the sizes though. Dave
1925 mostly original coupe.
Randall strickland
First Name: Randall
Last Name: Strickland
Re: Safety wire
Post by Randall strickland » Mon Oct 28, 2019 6:29 am
if you want plain old tie wire you can get it at most concrete places it is used to tie rebar.
Re: Safety wire
Post by John kuehn » Mon Oct 28, 2019 9:55 am
Ace hardware has safety wire in different sizes.
TonyB
First Name: Tony
Last Name: Bowker
Re: Safety wire
Post by TonyB » Tue Oct 29, 2019 12:59 am
I use 0.032” wire from McMasters
Tony Bowker
La Mesa, California
