What are these wood rails
Topic author - Posts: 194
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
These wood rails and corners were in a bunch of stuff I aquired. It was a mix of parts from Model T, Model A, and ?? Does anybody recognize them?
- First Name: Tony
- Last Name: Bowker
Re: What are these wood rails
I think the first picture appears to be the door striker support on touring and or roadsters. Some scale would help
Tony Bowker
La Mesa, California
La Mesa, California
The frame rails (if that’s what they are) look like they could be for a Roadster of some kind.If you have a T measure the distance between the front and center body to frame rail mounts ,center to center. If you have some holes that measure the same distance on your wood maybe that’s what it’s for?? Just a guess.
- First Name: Pete
- Last Name: Eastwood
Model A's that had wood sub rails were; 1930 / 31, A - 400, Victoria, & 2 door sport phaeton.
Looks like you have parts for one of those body styles !
- First Name: David
- Last Name: Dewey
Well, actually, many A bodies had wood side rails: Fordor Sedans, Cabriolets, Convertible Sedans, Vickys. These are not from the Fordors, nor the cabriolets, I would suspect Vicky or Convertible Sedan.
T'ake care,
David Dewey
David Dewey
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
They look like they may fit a Model A Vicky by the curve in the back, I don't know about a delux convertable 2dr Sd, so few of those were made.
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
The top picture looks like my 31 Victoria frame rails and rear seat armrests. Art
Curious but who makes Model A wood. Is it avaliable for most A’s? I have Model T’s along with most on the T forum and getting a wood kit for T’s isn’t always easy and for some T’s getting harder to find a supplier that’s easy to get a hold of. Most of the time!
many dealers carry wood kits like;
https://www.mikes-afordable.com/category/1123D.html
The kits might be made by;
http://www.classicwoodproductsllc.com/
