Vaprizer outlet gasket
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Sun Dec 08, 2019 9:09 am
Does anyone know if the Vaporizer outlet tube gasket (Ford # 6270) is available anywhere or has anybody used anything else as a substitute? There is none on mine and it seems to work ok but thought maybe I should put one on. Maybe a proper size o-ring would work ok?
Re: Vaprizer outlet gasket
Post by Scott_Conger » Sun Dec 08, 2019 11:05 am
Honestly, if you have a vaporizor that is working "just fine", I would be inclined to leave it alone.
