1909-10 sidelight brackets
Topic author - Posts: 147
- First Name: Alex
- Last Name: Dragone
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
I am having a discussion with a friend and we would like to know if the 1909-10 brackets were originally made out of cast brass or pressed steel and brass plated. I have seen them both ways. It seems to me that originally they were brass plated steel. Can anyone shed light on this?
- First Name: Pete
- Last Name: Eastwood
Re: 1909-10 sidelight brackets
Pressed steel & brass plated .
Peter E would KNOW !
- Last Name: Gresh
The side light brackets were pressed steel and brass plated as were the fire wall riser to windshield brackets. Tail light bracket was cast steel and brass plated as well.
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Steel and brass plated. Many other parts on the 09/10 Models were steel and bras plated including the emergency brake lever.
- First Name: Robbie
- Last Name: Price
The spark and throttle rods and hand crank were also brass plated steel.
- Last Name: Rosenthal
Alex: I cast them in Yellow brass because of the marginal quality of today's brass plating. Originals are heavy brass plated that can be repeatedly polished without wiping the brass off. You can lacquer coat these, but this is temporary protection and will rapidly tarnish under the lacquer. Some have cautioned that cast brass is weaker and therefore prone to a failure. This could be true if your casting alloy is junk, or if you are trying to use this bracket to jack up the car. You will not bend or break these parts by accidentally bumping them.
Regards,
Scott
Regards,
Scott
