This model L has steel choke and throttle arms so would it be mid or late prod ?
Thanks for any help.
Jim
[image][/image]
Help to ID carb
JW21TT
Topic author - Posts: 78
- First Name: Jim
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1921 TT Wrecker 1920 TT Tanker
- Board Member Since: 2012
Help to ID carb
- Attachments
- image.jpeg (24.14 KiB) Viewed 1396 times
- image.jpeg (27.69 KiB) Viewed 1396 times
- image.jpeg (27.3 KiB) Viewed 1396 times
Re: Help to ID carb
It is a Kingston L4. If it is iron body, used from 1921 to 1926. Can't tell from photos if bronze or iron body. If bronze would be a little earlier.
Corey Walker
- First Name: Corey
- Last Name: Walker
Re: Help to ID carb
Looks like a brass body L4. Those had a smaller bowl nut than the cast iron version. It’s also missing one of the arms for the choke, and it has a late model spray needle. Those bowls will interchange with the early NH bowls (to the left) but have a different drain.
