Help to ID carb
JW21TT
First Name: Jim
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1921 TT Wrecker 1920 TT Tanker
Board Member Since: 2012
Help to ID carb
Post by JW21TT » Sun Oct 11, 2020 10:32 am
This model L has steel choke and throttle arms so would it be mid or late prod ?
Thanks for any help.
Jim
[image][/image]
Re: Help to ID carb
Post by Mark Gregush » Sun Oct 11, 2020 11:29 am
It is a Kingston L4. If it is iron body, used from 1921 to 1926. Can't tell from photos if bronze or iron body. If bronze would be a little earlier.
Corey Walker
First Name: Corey
Last Name: Walker
Re: Help to ID carb
Post by Corey Walker » Mon Oct 12, 2020 3:43 pm
Looks like a brass body L4. Those had a smaller bowl nut than the cast iron version. It’s also missing one of the arms for the choke, and it has a late model spray needle. Those bowls will interchange with the early NH bowls (to the left) but have a different drain.
