Reproduction Parts
Reproduction Parts
Post by Original Smith » Sun Apr 09, 2023 10:43 am
Most of you are aware of sub-standard parts, but this one is important. I'm trying to help a new member with an original 1915. He needs the correct axle housing caps for the car, and they are not available. I think that is disgusting with the number of pre 1919 T's on the road today. I don't want to hear any crap about shimming them up either!
Re: Reproduction Parts
Post by Scott_Conger » Sun Apr 09, 2023 10:49 am
Just in case anyone does not understand the DEMAND part of "supply and demand"... :?
Last Name: Juhl
Post by Oldav8tor » Sun Apr 09, 2023 11:01 am
Are you talking about the steel caps with the felt washer that fit over the end of the rear axle tube? I have floating hubs and removed mine. Might still have them somewhere. I believe my 1917 would be the same as a 1915.
FWIW - I think most of the guys who stick with the original hyatt bearings have converted to modern neoprene seals which reduces the demand for the original type.
If you're talking about something completely different just ignore the above. :D
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Sun Apr 09, 2023 11:14 am
Larry,
Hope this helps!
Regards,
Last Name: Hatch
Post by Dan Hatch » Sun Apr 09, 2023 11:44 am
Is this what you looking for?
Email me Larry. Dan
Post by speedytinc » Sun Apr 09, 2023 1:11 pm
Caps need to be on hammer tight. I never considered shimming.
Have wondered why earlier caps were not available for decades.
I have modified the larger later cups to fit tightly on earlier housings by 2 small pie cuts & welding them shut.
Post by speedytinc » Sun Apr 09, 2023 1:12 pm
Email me Larry. Dan
I believe the flared flanges indicate the later caps.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Sun Apr 09, 2023 1:16 pm
Not a big fan of the machined caps. I get the standard cap and run a small internal bead on my bead roller. Installs and stays on well. I realize not everyone has a bead roller but if you ask around you’ll probably find someone that does.
Andy
Post by Jerry VanOoteghem » Sun Apr 09, 2023 2:15 pm
Larry,
Hope this helps!
It helped me!!!! :)
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Sun Apr 09, 2023 3:51 pm
Larry, maybe it's time you got into the Model T parts manufacturing business !
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Apr 09, 2023 4:04 pm
Group hug for Larry. :)
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sun Apr 09, 2023 4:27 pm
I have a large post office box of original Axle caps. Don’t know if they would work on your friend’s car.
William L Vanderburg
1922 Center Door Sedan
Tom_Carnegie
Last Name: Carnegie
Post by Tom_Carnegie » Sun Apr 09, 2023 5:25 pm
I have a few NOS early caps.
Post by John kuehn » Sun Apr 09, 2023 5:30 pm
Speedytinc Noted that he wondered why the earlier style haven’t been around for a good while.
It could be that the folks who make the later ones thinks they were all the same. It’s a detail that might have been overlooked.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Apr 09, 2023 5:32 pm
Post by Wayne Sheldon » Sun Apr 09, 2023 5:49 pm
I managed to scrape up enough originals for my two current brass cars. I was all set to do a small slice cut and weld or heat and shrink of a later pair to make fit the earlier housings, when digging in a box of model T stuff I found another pair I did not remember having.
I am not sure whether cut and weld or heat and shrink would be easier to make look and fit best? But either way would work and take a lot less time than trying to make something from scratch.
Last Name: Hatch
Post by Dan Hatch » Sun Apr 09, 2023 6:12 pm
I don’t know anything about flanges, but these start on a housing for a 15 WT and will not even try to start on a 26 housing.
Came out of a Ford dealer in the 50s. Dan
Post by Original Smith » Mon Apr 10, 2023 10:20 am
Thanks for all the meaningful posts! I believe my friend has found a pair. He will know in a week. I do believe that Lang's and Snyder's should join forces and get the correct ones made with all the pre 1919 cars that are still on the road!
Post by Steve Jelf » Mon Apr 10, 2023 1:50 pm
Some people install the TP backwards so their cat can't unwind it.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Apr 10, 2023 2:07 pm
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Mon Apr 10, 2023 2:21 pm
Just standing on the sidelines eating my popcorn while looking at toilet paper patents, and it made me wonder, so Larry, I am curious what amount of these would need to be manufactured correctly to fill the immediate need and how many need to go into inventory to supply hobbyists in the future? Are you thinking 10 sets, 100 sets, or or 500 sets?? How much do you feel the average hobbyist would be willing to pay for these if they were correctly made???
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 10, 2023 5:37 pm
Having made the mistake of reproducing some rare T parts (exact copies) and everyone tries to grind me on the price, it’s hard to get much sympathy for the whiners!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Apr 10, 2023 5:40 pm
Amen Brother Les!
Post by TXGOAT2 » Mon Apr 10, 2023 6:31 pm
You could move 40,000 of them, easily, if you could produce 20,000 value-priced cars.
Post by Jerry VanOoteghem » Mon Apr 10, 2023 6:36 pm
You first.
Post by TXGOAT2 » Mon Apr 10, 2023 6:40 pm
It's no longer legal to produce value-priced automobiles in this country.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Apr 10, 2023 9:07 pm
If you could produce value priced electric cars it would be legal & you would make a millions. But we know thats not going to happen as long as
the goverment will subsidize for special conciderations. Damn my tin foil hat fell off!
Post by Original Smith » Tue Apr 11, 2023 11:07 am
John Von Karvaly nailed it. I believe the photos Dan posted are the later design. I don't understand what toilet paper has to do with this post!
Post by speedytinc » Tue Apr 11, 2023 1:15 pm
They are a tight hammer on fit. If they will slip on an early (15) housing, without a hammer, they are the later size. Seeming to not start on a later housing would be a normal situation. They fit that tight.
The early cups typically dont have the curved flange on the edge.
slang250
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1926 speedster, 1926 TT
Post by slang250 » Thu Apr 27, 2023 11:33 am
Be careful when checking original unused caps if they are the early version or later version.
Ford did make some of the earlier smaller diameter caps with with the flange on them.
The ID of the caps should be 2.382-2.384" on the earlier smaller caps if NOS and 2.429-2.431" on the later NOS larger caps.
We have a few pairs of NOS smaller diameter caps available.
Thank You Steve
