question on how to adjust/test coils
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Tue Jul 08, 2025 11:23 am
one of my coils are weak, i know because when starting if the commutator is rotated such that one of the coils is buzzing before i crank it, sometimes i hear a strong buzz other times its weaker, and sometimes its real strong, I don't know which coil(s) are making the weaker noise nor do I have access to a tester, how do I get them all going about the same to get consistent spark? this might explain how the car seems off in high gear.
Re: question on how to adjust/test coils
Post by speedytinc » Tue Jul 08, 2025 11:32 am
Have them tested/adjusted on an ECCT. Coil tune is critical for a good running T.
If you cant find someone with a tester, consider an aftermarket distributor.
Post by Jerry VanOoteghem » Tue Jul 08, 2025 11:33 am
You can't really judge coil performance by sound. How does the car run? Any misfires?
Post by TXGOAT2 » Tue Jul 08, 2025 11:36 am
The sound a coil makes does not necessarily indicate its condition. I adjusted all 4 of my coils to sound about the same and the car would barely run. The only way to correctly adjust the KW type coils is to use an HCCT or ECCT. All 4 coils can deliver a strong spark and still be out of adjustment. The very early type coils can be adjusted "by ear", but not the later type. One reason the early coils were adjusted by ear is that they had no better way of doing it.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jul 08, 2025 12:46 pm
Suggest you contact one of the coil folks listed on the forum suppliers page. Best to send them off and have them adjusted/ rebuilt for best results.
https://www.mtfca.com/model-t-ford-suppliers/
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Tue Jul 08, 2025 1:12 pm
I mean in high gear something feels off, I can't put a finger on it but the t is telling me something is not quite right. Low and reverse are boo noisy to tell anything based off gut feeling and idle is fine. Just in high it feels off. It might be me being off my rocker but it doesn't feel right.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Tue Jul 08, 2025 1:14 pm
I mean the weaker one sounds notably quieter and grobbles not buzzes like the others, y'all said noise isn't big an indicator but with it seeming off in high gear plus the odd sounding coil(s) shouldn't that mean something?
Post by speedytinc » Tue Jul 08, 2025 1:26 pm
Regarding sound. I have adjusted enough coils on an ECCT. During the process, one can hear differences that coincide with a tune improving.
The final very good passing coil has a definite, clear, loud clack, as opposed to a weak buzzing. There is no way I could get that sound & performance without aid of electronic equipment. There are two many adjustment variables with the points.
Having a good running T on a coil & timer system takes a real commitment.
Those that don't have that commitment can still enjoy other aspects of T driving with a distributor.
I learned this getting my timer & coil system to its optimum ignition performance.
Last Name: Hatch
Post by Dan Hatch » Tue Jul 08, 2025 1:36 pm
Start by reading the Ford Service Manual, then move on to the club video on coils.
Then spend several hundred dollars getting the right tools to adjust coils. Or send them to a coil person and get them repaired. Dan
Post by TXGOAT2 » Tue Jul 08, 2025 2:35 pm
Inspecting your spark plugs can tell you a lot about how the different cylinders are performing. What kind of timer do you have? Have you cleaned or lubricated it recently? Is your fuel filter clean? What about the carburetor adjustment? Have you tried adjusting the carburetor while driving down the road to see if performance improves? Is the choke releasing fully? You may have bad points, a bad condenser, a coil with poor adjustment, a timer issue, a wiring issue, a spark plug issue, or a fuel/air issue. (Among others).
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Jul 09, 2025 11:27 am
Open up one of those coils and examine the capacitor.
You will find two rolls of tin foil with two rolls of wax paper between them.
The capacitor is attached to the two coil points, and they have to be open for measurements.
If the capacitor is shorted, rather than open, there will be no sparks at the points or the spark plug.
If the capacitor is open the points will work for a short time and then weld themselves shut.
The best solution is to have the coils rebuilt by one of two professional rebuilders that I can recommend!
Post by TXGOAT2 » Wed Jul 09, 2025 11:50 am
It would be a good idea to determine what the problem is before trying to remedy it.
Post by Jerry VanOoteghem » Wed Jul 09, 2025 2:03 pm
The best advice so far...
Get a known good set, (and a spare coil), and remove that variable from your problem solving process.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Jul 09, 2025 9:15 pm
Put another way, "Has anyone ever replaced the points on an original coil and found the capacitor was still good?"
I am kind of new yet, I have only been testing coils for 45 years, and I have a Capacitor Tester, an ECCT with the Computer Program, a StroboSpark, A New and Old Stafford Coil Tester, and two restored HCCTs, but I have never found an original coil with a good capacitor!
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Jul 09, 2025 11:27 pm
Best bang for the buck are rebuilt coils by a competent professional rebuilder. It’s the only way your T will be in normal sinus rhythm. You’d be surprised how much better your T will run, even if it’s a tired engine. Like Dan said paraphrased, you could buy about $800 + of equipment plus a lot of learning the technique & still not be competent or spend around $300 + or- for a set of 5 coils rebuilt by someone that knows what they’re doing. I’m speaking from experience. I have a HCCT, 2 strobo sparks and an ECCT with computer upgrade. Yes I’m a glutton for punishment. I finally realized that it wasn’t the equipment but the technician. I fired me & send them off to my go to guy. Best John
Post by Original Smith » Thu Jul 10, 2025 12:21 am
Get Ron Patterson to rebuild them. They will last forever.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Jul 10, 2025 3:26 pm
Ron and John have been the "best of friends" for many years.
That is about the same with Ron and me.
Early in production, Ron suggested I should get a StroboSpark and I bought one.
A few weeks later, Ron asked me how I liked it.
I told him I was going to send my unit back, as it does not seem to work right and always tells me the capacitor is bad.
Ron told me he assisted John in the development and got one in the early days of sales.
He always used the StroboSpark to test each coil sent for repair to determine if it was worth rebuilding.
At that time, he had tested and rebuilt 2,500 coils and found about 40 had a good capacitor.
My unit still works fine now!
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Jul 10, 2025 3:37 pm
Another recommendation to send them out. The turn around time usually isn’t too bad. Simply put you cannot adjust a coil without a tester.
Andy
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Jul 10, 2025 9:25 pm
Another good plan is to keep a spare restored set, just in case you or one of your friends need some or one.
Some T owners carry one or two, a set of spark plugs, a spare timer and a spare carburetor., along with the spare tire and often a new tube.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Jul 11, 2025 7:08 am
.. Extra Restored coils should be kept in a secure, protected environment such as a locked coil box or packaged in cardboard to protect the point set on top of coils from any pressure or physical damage to offset coil calibration. Ignition coils that are kept under the seat in a car are subject to being out of proper settings.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Jul 11, 2025 1:19 pm
That device will tell you when a coil is bad if you get no sparks.
I cannot tell you the coil has a good capacitor!
There is no capacitor tester on this device.
If the capacitor was not important, the coil would not have one!
Henry was not one to hang on the bells and whistles on his T parts.
John Codman
Last Name: Codman
Post by John Codman » Fri Jul 11, 2025 2:14 pm
I sure agree with this.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sat Jul 12, 2025 7:17 am
They say that the two best days in a boat owner's life are the day he (she) buys it, and the day he (she) sells it.
The two best days in a Model T owner's life are the day he (she) buys it, and the first time he (she) drives it with a properly adjusted set of coils.
Anyone who disagrees has yet to experience day 2.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sat Jul 12, 2025 8:20 am
I was a buzz box guy. Even built and sold a few on E Bay. This was years ago and I was taught a lesson when a friend who lives not far from me contacted me through the Forum. He had an HCCT and did coils for the local club. I had rebuilt mine, ( cap, points etc ) and he came over and set them up for me. My car started, dead cold, on the hand crank after we reinstalled them. Brother I was sold.
Post by TXGOAT2 » Sat Jul 12, 2025 8:33 am
A buzz box is much better than trying to adjust coils "by ear". But an HCCT is FAR BETTER, and an ECCT is best.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Jul 13, 2025 9:17 am
Perhaps another trade secret.
You can slowly increase the cranking speed of a HCCT that has two meters and watch the AC Volt Meter reading increase when you increase the speed until the sparks happen around the spark ring.
That lets the spark happen at a slightly different voltage level for each coil.
That spark also happens with the piston at a slightly different level and can cause a slightly different power level on the running engine that is not providing quite such as possible smooth an operation.
The ECCT sets all the coils to make sparks happen at exactly the same voltage level and that does provide a smoother running engine with a little more power.
Moxie26
Post by Moxie26 » Mon Jul 21, 2025 6:55 am
If you still have one coil buzzing all the time there is a short in the wiring somewhere.. and that has nothing to do with coil calibration....... Even when equally calibrating your four coils , each coil will have its own distinct sound when firing in the car probably due to things such as tightness and condition of top hardware, condition of the wood case, the amount and condition of the poured tar in the coil..... so many possible variations exist..... Not to mention the condition of the coil box that hold all four coils.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Jul 21, 2025 3:19 pm
If you turn the crank just a little bit, and the buzzing stops, you are OK.
If the buzzing continues, you have a problem!
