Does anyone have photographs of original Rock Mountain Brakes? The Complete Set? Every last piece?
NorthSouth
Last Name: California
Post by NorthSouth » Mon Aug 18, 2025 6:24 pm
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Does anyone have a photograph of an original Rock Mountain Brake “pedal clamp”?
Post by ThreePedalTapDancer » Mon Aug 18, 2025 6:51 pm
Larry Smith posted a pic of original clamp back in 2016. Looks like it would be easy to make, I would suggest using an aircraft eye bolt from aircraft spruce. You may have to extend the threads further on shank, just an idea.
https://www.mtfca.com/discus/messages/5 ... 1478740557
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Aug 18, 2025 7:14 pm
These fixture bolts are an even closer match
https://www.carrlane.com/product/clampi ... ts/cl-1-sb
Post by RajoRacer » Mon Aug 18, 2025 7:14 pm
Here's another photo - Ed has a great suggestion !
Post by TRDxB2 » Mon Aug 18, 2025 7:24 pm
Swing Bolts
Post by Original Smith » Thu Aug 28, 2025 9:27 am
Those hinge pin swing bolts are very close, but need to be modified to be correct.
Rajo23
Last Name: Goertzen
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
Post by Rajo23 » Thu Aug 28, 2025 11:54 am
Swing Bolts
This isn't a "photograph of an Rock Mountain Brake 'pedal clamp'!
Edit: Thank you Larry for the correction below!
Post by Original Smith » Thu Aug 28, 2025 12:08 pm
It certainly is!
NorthSouth
Post by NorthSouth » Sun Aug 31, 2025 10:17 pm
Found One.
Now I just need the C clamp.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Sep 01, 2025 1:21 am
The C clamp looks like it would be easy to fabricate.
Post by RajoRacer » Mon Sep 01, 2025 12:55 pm
C-clamp material - 3/16 x 3/4 flat stock w/rounded edges - Mc Master-Carr.
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Mon Sep 01, 2025 6:39 pm
Here's a picture of the one I made to use on my AC Brakes...
Post by speedytinc » Mon Sep 01, 2025 9:12 pm
The pedal linkage unit appears to be unused. mounts to pivot from the DS tube.
Pedal clamp is 2 pieces cast to clamp onto pedal with 1/4" bolts.
Drums are riveted together.
Obviously made for a cable that automatically equalizes.
I dont know if this is an original RM brand set or a Sunderland reproduction.
Post by RajoRacer » Mon Sep 01, 2025 10:32 pm
John - I have a set of both - the main bracket you are showing is an original. The Sunderland drums are cast in one piece.
Post by Original Smith » Tue Sep 02, 2025 12:08 pm
When Eaton took over the production of Rocky Mountain products, they made a number of changes, some good, some not so good.
NorthSouth
Re: Does anyone have photographs of a complete set of “original” Rock Mountain Brakes? Including all components.
Post by NorthSouth » Tue Sep 02, 2025 2:25 pm
This is what I have collected so far;
NorthSouth
Post by NorthSouth » Tue Sep 02, 2025 2:33 pm
Original Smith wrote:
Tue Sep 02, 2025 12:05 pm
I'll stick with the original design.
Larry,
What is the “original design” that you referred to?
Would you be able to provide more information or “photographs”.
Those following this thread would benefit from more elaboration.
ewdysar
First Name: Eric
Last Name: D
Re: Does anyone have photographs of original Rock Mountain Brakes? The Complete Set? Every last piece?
Post by ewdysar » Tue Sep 02, 2025 5:46 pm
My "modern" Rocky Mountain brakes have rods with the associated equalizer. If I were to convert "back" to cables, two questions:
Did the originals interact with the parking brake, and if so, how? Or since I already have the equalizer installed and linked to the brake pedal and parking brake, should I just replace the bracket that the brake rods attach to with something (see next question) to pull the cables?
I've recently seen pics posted showing a "y-shaped" channel to pull the brake cables, and others show a pulley to do the same. The pulley seems like it would be better for equalization. Which method was used with the original set-up?
Keep crankin',
Eric
Post by speedytinc » Tue Sep 02, 2025 6:18 pm
Keep crankin',
Eric
Originals are not integrated with the parking brakes.
I have seen the pulley setup before. I believe it was original. The u piece on my setup is new to me, but I believe it will work equally well.
That piece is the same all of the parking brake setups for 60's fords & probably many others used. Both these pieces provide simple & cheap self equalization.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Sep 02, 2025 11:13 pm
John- your equalizer assembly was made by me for use with my small drum AC brakes that I reproduced for many years. Just don't want folks to get confused with original versus reproduction parts. Dan
Post by speedytinc » Wed Sep 03, 2025 8:05 am
Thanks Dan. I appreciate the info.
Makes sense being in new condition & came with a set of AC small drum brakes & the RM's I pictured.
Post by Original Smith » Wed Sep 03, 2025 12:45 pm
Why not come over! I have every part, and none of it is for sale. The threads on the hinge bolt are fine thread.
Post by Original Smith » Thu Sep 04, 2025 10:56 am
For the benefit of those who have original Rocky Mountain brakes, I had all the springs reproduced, and are for sale @ $5.00 each.
Post by Original Smith » Sun Sep 07, 2025 10:35 am
There are several photos of original parts pictured. You are almost there. If you decide to visit, you can take your own pictures!
NorthSouth
Post by NorthSouth » Sun Sep 07, 2025 1:06 pm
Great news Larry,
I would like a full complete set and agree to the increase ($10 each) for the “rear conical springs”. I will send you a check. What is the total cost including local shipping?
Post by Original Smith » Sun Sep 07, 2025 1:07 pm
I made a mistake on the brake springs. The barrel springs are $10 each, and the conical springs are $15. You don't even want to know how much it cost me to have these made!
Post by Original Smith » Mon Sep 08, 2025 6:45 pm
What is surprising to me is the sudden interest in REAL Rocky Mountain Brakes. I know the whole story on the repros from the start, so it's up to the owner to decide which way to go. In the early '60's the Rocky Mountain Brakes started to be made correctly, but the guy that had them made had no mechanical knowledge, so decided to use a Bennett equalizer instead of what is correct. The current offerings are copies of an A.C. brake used in 1926. I was young in the hobby then and didn't have the knowledge I now have. When reproducing anything, it is imperative to do your research on the subject. At first, I didn't know what the pedal clamp looked like until about 10 years ago, so I now have that corrected. The superior aspect of the first series brake drums is they were cast. I have three Model T's, and have been able to locate original parts for all of them.
Rajo23
Last Name: Goertzen
Post by Rajo23 » Mon Sep 08, 2025 7:04 pm
Larry,
Could you post numerous detailed photos of your Rocky Mountain Brakes? Seeing these photos would greatly further my research.
This would also benefit those of us who live hundreds of miles away.
Thank you!!
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Sep 08, 2025 7:42 pm
NorthSouth
Post by NorthSouth » Wed Sep 10, 2025 6:17 pm
Larry “Original” Smith just sold me this brand new, period correct, spring kit for my now complete set of original Rocky Mountain Brakes.
“$37.99”
Doing things correctly can be expensive.
Post by RajoRacer » Wed Sep 10, 2025 8:21 pm
Steve - if the R.M. brakes you posted the photo of above are what you have - those are Sunderlin repros - I currently have a set of both. John K. posted a photo of an original just above yours - note the "oversize" hole and the smaller hole above it which you apparently drilled a hole in the original small drum backing plate
Post by Original Smith » Thu Sep 11, 2025 12:16 pm
There is no excuse for doing things incorrectly. I'm not a camera type, and don't wish to try and do so. However, I encourage anyone who is to come over and start taking pictures. I bought my first set of R.M. brakes from Chris Eggsgard when I was a teenager, and have managed to find enough parts to put them on all of my cars.
NorthSouth
Post by NorthSouth » Thu Sep 11, 2025 9:35 pm
I just had an informative visit with Mr Ed in Hayward and he assured me that my “Sunderlin” Brakes are are a correct copy of the original Rocky Mountain Brake design and will operate in both forward *and in reverse*.
So, I will keep this now complete setup and put them, and the new cast iron brake drums, on the 1924 Paco bodied speedster.
Post by RajoRacer » Thu Sep 11, 2025 9:56 pm
Yes, they are somewhat correct BUT they are not exactly as the originals ! Tell Ed "Hi" from Tomaso !
Post by Original Smith » Fri Sep 12, 2025 2:47 pm
Some people only know half the story! Sunderlins first attempt at making R.M. brakes was pretty good. Where he messed up was he didn't know what the rest of the setup looked like, and unfortunately chose a Bennett equalizer! That was a huge mistake, and to this day Buds Rocky Mountain brakes are 100% incorrect!
When Tractor Train took over making the brakes, they made some improvements. Why they added to the bracket mentioned above is not known.
I have been around since the start of this venture, and what I say is true. The first series cast drums are very nice. I have a set of these on one of my cars. All I had to do was machine the casting marks off the inside of the drums, and put a radius on the upper corner.
Post by Original Smith » Sat Sep 13, 2025 12:55 pm
If Jack Sunderlin had photos of every original part, we wouldn't have the disaster we have today!
