Does anyone have photographs of original Rock Mountain Brakes? The Complete Set? Every last piece?
Topic author - Posts: 598
- Last Name: California
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
- First Name: Ed
- Last Name: Martin
Re: Does anyone have a photograph of an original Rock Mountain Brake “pedal clamp”?
Larry Smith posted a pic of original clamp back in 2016. Looks like it would be easy to make, I would suggest using an aircraft eye bolt from aircraft spruce. You may have to extend the threads further on shank, just an idea.
https://www.mtfca.com/discus/messages/5 ... 1478740557
- First Name: Kevin
- Last Name: Pharis
Here's another photo - Ed has a great suggestion !
Swing Bolts
Those hinge pin swing bolts are very close, but need to be modified to be correct.
Found One.
Now I just need the C clamp.
Found One.
- First Name: Keith
- Last Name: Townsend
The C clamp looks like it would be easy to fabricate.
C-clamp material - 3/16 x 3/4 flat stock w/rounded edges - Mc Master-Carr.
- First Name: Kent
- Last Name: Palazzo
Here's a picture of the one I made to use on my AC Brakes...
Pedal clamp is 2 pieces cast to clamp onto pedal with 1/4" bolts.
Drums are riveted together.
Obviously made for a cable that automatically equalizes.
I dont know if this is an original RM brand set or a Sunderland reproduction.
John - I have a set of both - the main bracket you are showing is an original. The Sunderland drums are cast in one piece.
I'll stick with the original design.
When Eaton took over the production of Rocky Mountain products, they made a number of changes, some good, some not so good.
Re: Does anyone have photographs of a complete set of “original” Rock Mountain Brakes? Including all components.
This is what I have collected so far;
Larry,
What is the “original design” that you referred to?
Would you be able to provide more information or “photographs”.
Those following this thread would benefit from more elaboration.
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: Does anyone have photographs of original Rock Mountain Brakes? The Complete Set? Every last piece?
My "modern" Rocky Mountain brakes have rods with the associated equalizer. If I were to convert "back" to cables, two questions:
Did the originals interact with the parking brake, and if so, how? Or since I already have the equalizer installed and linked to the brake pedal and parking brake, should I just replace the bracket that the brake rods attach to with something (see next question) to pull the cables?
I've recently seen pics posted showing a "y-shaped" channel to pull the brake cables, and others show a pulley to do the same. The pulley seems like it would be better for equalization. Which method was used with the original set-up?
Keep crankin',
Eric
Keep crankin',
Eric
Originals are not integrated with the parking brakes.ewdysar wrote: ↑Tue Sep 02, 2025 5:46 pmMy "modern" Rocky Mountain brakes have rods with the associated equalizer. If I were to convert "back" to cables, two questions:
Keep crankin',
Eric
I have seen the pulley setup before. I believe it was original. The u piece on my setup is new to me, but I believe it will work equally well.
That piece is the same all of the parking brake setups for 60's fords & probably many others used. Both these pieces provide simple & cheap self equalization.
- First Name: DAN
- Last Name: MCEACHERN
John- your equalizer assembly was made by me for use with my small drum AC brakes that I reproduced for many years. Just don't want folks to get confused with original versus reproduction parts. Dan
Thanks Dan. I appreciate the info.Dan McEachern wrote: ↑Tue Sep 02, 2025 11:13 pmJohn- your equalizer assembly was made by me for use with my small drum AC brakes that I reproduced for many years. Just don't want folks to get confused with original versus reproduction parts. Dan
Makes sense being in new condition & came with a set of AC small drum brakes & the RM's I pictured.
Why not come over! I have every part, and none of it is for sale. The threads on the hinge bolt are fine thread.
For the benefit of those who have original Rocky Mountain brakes, I had all the springs reproduced, and are for sale @ $5.00 each.
