Screw size for dash shield
Tbird
Last Name: Bird
Post by Tbird » Sun Feb 07, 2021 4:17 pm
I just got a dash shield and guide for a two piece dash 11-12. Unfortunately the dash shield did not come with the mounting hardware (screws).
I do know that the screws are to be #6 Slotted Round head but what is the length? Thanks
Mike
Re: Screw size for dash shield
Post by Allan » Sun Feb 07, 2021 4:33 pm
Not so long that they go right through the firewall. No-one will know if you use some thatare a bit shorter than Henry used.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Feb 08, 2021 12:40 am
Mike-
I'm sure someone who has those specifications will post it. Regardless of the length, I would suggest you drill the holes and "thread" the wood using a matching thread steel Phillips head screw before you put in the slotted French head brass screw.
Those fancy brass screws have a tendency to twist in two. Don't ask me how I know.
Keith
Post by Original Smith » Mon Feb 08, 2021 10:13 am
Keith, I hear you on that one. I had it happen to a #8 oval hood former screw. It was a chore to remove it.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Mon Feb 08, 2021 4:51 pm
Years ago an old timer told me to soap wood screws to ease their passage into the wood. Is anyone doing this now? Do they come loose more easily?
Tbird
Last Name: Bird
Post by Tbird » Mon Feb 08, 2021 5:20 pm
Great ideas guys!
Mike
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Mon Feb 08, 2021 9:42 pm
Soap definitely works! Dad's favorite trick. Great idea on prethreading the hole! Cheers, Bill.
MikeinTexas
First Name: Michael
Last Name: Krom
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1923
Post by MikeinTexas » Mon Feb 08, 2021 11:12 pm
Dad's trick was to scrape the woodscrew threads across a piece of Bee's Wax!
Something I still do!
dr1960
First Name: David
Last Name: Ruedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Post by dr1960 » Mon Feb 08, 2021 11:30 pm
I have used the soap and bee's wax trick for years! My grandfather always had a small bar of soap in his toolbox and he would drill a hole in the wooden handle of his hammer and put bee's wax in it so as to always have it on hand!
David - Yukon, OK
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Tue Feb 09, 2021 2:18 pm
I just ran the No. 9 brass wood screws into the dash to hold the horn. It was hard going in dry, I had forgotten the old wisdom. Oh well, next time!
