Screw size for dash shield
Tbird
- First Name: Mike
- Last Name: Bird
I just got a dash shield and guide for a two piece dash 11-12.  Unfortunately the dash shield did not come with the mounting hardware (screws).
I do know that the screws are to be #6 Slotted Round head but what is the length? Thanks
Mike
Mike
Re: Screw size for dash shield
Not so long that they go right through the firewall. No-one will know if you use some thatare a bit shorter than Henry used.
- First Name: Keith
- Last Name: Townsend
Mike-
I'm sure someone who has those specifications will post it. Regardless of the length, I would suggest you drill the holes and "thread" the wood using a matching thread steel Phillips head screw before you put in the slotted French head brass screw.
Those fancy brass screws have a tendency to twist in two. Don't ask me how I know.
Keith
Keith
Keith, I hear you on that one. I had it happen to a #8 oval hood former screw. It was a chore to remove it.
Hudson29
- First Name: Paul
- Last Name: O'Neil
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1923 Runabout
Years ago an old timer told me to soap wood screws to ease their passage into the wood. Is anyone doing this now? Do they come loose more easily?
Tbird
- First Name: Mike
- Last Name: Bird
Great ideas guys!
Mike
						Mike
				It's Bill
- First Name: Bill
- Last Name: Hoffer
Soap definitely works! Dad's favorite trick.  Great idea on prethreading the hole!  Cheers, Bill.
				MikeinTexas
- First Name: Michael
- Last Name: Krom
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1923
Dad's trick was to scrape the woodscrew threads across a piece of Bee's Wax!
Something I still do!
dr1960
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
I have used the soap and bee's wax trick for years!  My grandfather always had a small bar of soap in his toolbox and he would drill a hole in the wooden handle of his hammer and put bee's wax in it so as to always have it on hand!
									David - Yukon, OK
Hudson29
- First Name: Paul
- Last Name: O'Neil
I just ran the No. 9 brass wood screws into the dash to hold the horn. It was hard going in dry, I had forgotten the old wisdom. Oh well, next time!
