11 hubcaps
Art Ebeling
First Name: Art
Last Name: Ebeling
11 hubcaps
Post by Art Ebeling » Fri May 03, 2019 12:04 pm
I plan to attend a swap meet Sunday at Gateway by St. Louis. Can someone post pictures of the correct hubcaps for a late Oct 11 Touring? Thanks, Art
Last Name: Strange
Re: 11 hubcaps
Post by CudaMan » Fri May 03, 2019 1:55 pm
Royce has a whole series of articles on details of the 1911 and 1912 model years on his forum.
https://modeltfordfix.com/forum/viewtop ... f=11&t=583
Last Name: Wrenn
Re: 11 hubcaps
Post by TWrenn » Fri May 03, 2019 2:01 pm
Lets see if this works! I pirated this little bit-a info off the encyclopedia for you to get you started.
July 13, 1911 The top surface is now flat with a thin rim around the outer edge (the name area is recessed) with the standard "Ford" script. The background is oxidized. This style is typical of late 1911 and most of 1912.
July 13, 1911. Note the recessed top surface with the thin "rim" around the top.
[/size]
First Name: Keith
Last Name: Townsend
Re: 11 hubcaps
Post by KWTownsend » Sat May 04, 2019 12:23 pm
Art-
These are the hubcaps that Tim is talking about:
I have a set of these for my Oct-Nov 1911. The background will be black oxidized, not painted.
If you look at original photos from the era it is hard to identify what type are on the cars. I have seen many late 1911s (like Phil Mino's) that have the early 1911 style hubcap.
You mileage may vary.
Keith
Art Ebeling
First Name: Art
Last Name: Ebeling
Re: 11 hubcaps
Post by Art Ebeling » Sat May 04, 2019 1:44 pm
Thank, Now I know what to look for. Art
Last Name: Strange
Re: 11 hubcaps
Post by CudaMan » Mon May 06, 2019 9:17 pm
Art, did you find your hubcaps? I talked to Forrest at the swap meet and he told me you came by.
