Anyone with a speedster and a Ruckstell and hand brake on the left outboard off the body?
skyhunter
First Name: Donncha
Last Name: OapostropheMurchu
* REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
Post by skyhunter » Wed Feb 14, 2024 12:45 am
Be interested in pictures or diagrams showing how it was done.
Love to be able to have both on the outside of the body on the left-hand side and would like to see how others who have done it accomplished it.
I have seen one's with the brake lever moved outboard but not also the shifter.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Anyone with a speedster and a Ruckstell and hand brake on the left outboard off the body?
Post by Kevin Pharis » Wed Feb 14, 2024 2:02 am
Here is (a bad) pic of my outboard Ruxtel and e-brake levers. I don’t hand crank this car so abandoned the ratchet mechanism. It makes parking a bit tedious at times, but oh well! Both are made from modified e-brake levers, the brake lever is 3/4” shaft, and the shift lever is welded to a piece of tube that pivots on the brake shaft
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Wed Feb 14, 2024 10:55 am
I'll be tackling the same on my speedster. On the last one I built, I made a new cross shaft / e brake shaft that goes underneath the driveshaft, but with a 6 inch extension on the driver side. Moved the ratchet mechanism to the outside of the body, making a bracket that braced on the underside of the seat, and then a tab that went down to connect to the cross shaft so when you pull the ratchet lever on the shaft and bracket cannot flex independently. I left the normal shaft underneath the back of the transmission pan and then ran a remote rod between the two. I'll see if I can dig up some pictures.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Feb 14, 2024 10:40 pm
Hi Iu'dai,
I did not put the park brake outside the the body but did move the the Ruckstell shifter out side the body. I mounted the shifter on the radius
rod & drive shaft tube so the shifter moves with the driveline outside independent of & under the body. I installed the shift lever up so the shift handle is reversed from normal. ( Ruckstell forward & Ford back )
skyhunter
First Name: Donncha
Post by skyhunter » Wed Feb 14, 2024 11:42 pm
Thanks for the info, keep it coming.
Found these 2 pics. Love to see the undersides of these cars. My car has one of those brake equalizer set ups for a 20-27 T that allows the brake to work as either foot operated or the hand brake lever. But I am removing it and going to just stock style lever E-Brake.
I want to use a Model A brake lever for the outboard left-hand shift lever for the Ruckstell and the OEM lever as is but keep the left side E-brake connection in the stock location. Craig, I like how you got yours going in opposite directions. I imagine if I have both outboard, I will have to take the knee bend out of them.
kelly mt
Last Name: Kelly
Post by kelly mt » Sat Feb 17, 2024 12:52 am
Here is how it was done on my '23 Speedster.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Feb 18, 2024 1:33 pm
Hi Skyhunter,
I was unable to email these so I'll post them.
Hope this helps. Sorry about the mess I haven't cleaned it up since the last speedster run.
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Sun Feb 18, 2024 8:02 pm
Well, I have not built this set-up but I have thought about it. It uses a factory parking brake shaft extended to the outside of the speedster body. A tube with a handle welded on slides over the extended section of the parking brake shaft. The factory emergency brake handle then goes on. For a speedster appearance, a “gate style” quadrant goes around the Ruckstell and emergency brake handles. It would require a clever Ruckstell shift rod to go from outside the frame to the shifter on the Ruckstell.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Feb 19, 2024 12:56 am
Hi Chris,
Thanks for posting that drawing I will print & save that.
skyhunter
First Name: Donncha
Post by skyhunter » Mon Feb 19, 2024 10:34 pm
Thanks Chris and Craig. I was thinking of doing the gate but having the levers off set using a Model A brake lever for the Ruckstell and possibly taking the knee bend out of the T lever. But I may want the extra separation. But the tube over shaft single mount look would be a lot cleaner.
I am going to do like Craig and have them go in opposite directions. Also going to try and get another right-side e brake end to use where the stock lever would have been for the left-side connection of the OEM brake rod. I think that would be easier to use than trying to use the cut-off end from the lever after it goes outboard.
Thanks for all the pictures.
IvanJ
First Name: Ivan
Last Name: Jorgensen
Post by IvanJ » Tue Feb 20, 2024 12:15 am
Ruckstel and Model T brake lever on the same shaft. All levers are farther back than stock location. Ruckstel shifter goes through, Model T brake lever goes forward to actual cross shaft that is Model T brake/shift handle.
