The Hunter Model T starter
Matt in California
Topic author - Posts: 786
 - First Name: Matt
 - Last Name: G
 - * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Has anyone see or used one of these?
I image they must not have been too good or we would see more.
Matt
						Matt
				Les Schubert
 - First Name: Les
 - Last Name: Schubert
Re: The Hunter Model T starter
I have one (at least the engine part). Haven’t installed it yet
Matt in California
 - First Name: Matt
 - Last Name: G
			Wow LesLes Schubert wrote: ↑Tue Jun 23, 2020 2:11 pmI have one (at least the engine part). Haven’t installed it yet
Now your car is worth three times as much
Or at least when you get it working...
Matt!
				tom_strickling
 - First Name: Tom
 - Last Name: Strickling
 - * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
I have one in a box.  A local 14 roadster pickup has one.  Thing is if it backfires while you a pull starting you may end up in front of the car!  Just jokin'
									“The trouble with retirement is that you never get a day off.” – Abe Lemons.
				tom_strickling
 - First Name: Tom
OOPS  I have to take that back, I thought it was one of the pull starters that has a D shaped handle on the firewall for you to pull on.
Susanne
 - First Name: Susanne
 - Last Name: Rohner
I actually had one on one of dad's cars years ago, but you need Schwarzenegger arms to pull it, or have cruddy compression.  Unless you're relying on a hot engine and semi-free starts, that pull starter is NOT like starting your lawn mower, it's tough!  WAY easier just to get out and crank it!
Fordwright
 - First Name: Greg
 - Last Name: Popove
How does it work?
Here's another version of pull chain mechanical starter from the dash.
Love the name......very appropriate.......think it would be a challenge to pull that handle sitting down behind the steering wheel
				OilyBill
 - First Name: William
 - Last Name: May
Using this type of starter is no trouble at all!
You just get the mother-in-law to put the heave to it.
The only drawback I see is that since I paid $5 for the car in the first place, it's now only worth $15. That's kind of a disappointing return on investment. Plus, the thing itself cost me $4.75. So now the car is still worth only $10.25.
Well, $10.40, if you count the nickels I hammered in as freeze plugs.
				OilyBill
 - Last Name: May
Some of you guys are PRETTY extravagant!!!
				D Stroud
 - First Name: David
 - Last Name: Stroud
 - Board Member Since: 2011
In todays world, that add would most likely be open for a lawsuit. That doesn't look like a "self starter" to me.
 Dave
									1925 mostly original coupe.
I did a an internet search and found several similar devices marketed at that time.  Some with good leverage for starting - not sure  how they handled kick-back.
http://www.mtfca.com/discus/messages/11 ... 1288920924 Boston Starter http://www.mtfca.com/discus/messages/80 ... 1254274560 Nicely installed http://www.mtfca.com/discus/messages/80 ... 1246395151 http://www.mtfca.com/discus/messages/80 ... 1246395151
Jay in N California planning to install a Simplex starter it http://www.mtfca.com/discus/messages/118802/124401.html
The SANBO http://www.mtfca.com/discus/messages/59 ... 1455282622 Where Briggs & Stratton got the idea http://www.mtfca.com/discus/messages/118802/168184.html
				Dropacent
 - Last Name: Morsher
VARIATIONS- The Hunter Model T starter
Variations of same theme.   I’m going to use the bottom one on a project, the top one is available to a tinkerer.   I’ve seen a foot-lever-from-the-seat design that intrigues me. Two repaired shoulders here.
Fordwright
 - First Name: Greg
 - Last Name: Popove
I recommend Kickstarter.  *chuckle*
				Harry Lillo
 - First Name: Harry
 - Last Name: Lillo
 - * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
I have a couple of different remote starters.
One is interesting in that it is a kick starter.
The starter is similar in shape to the existing pedals.
Makes the T a four pedal car!!
				Dropacent
Can you post a photo, Harry?
Fordwright
 - First Name: Greg
 - Last Name: Popove
Something tells me that only Mrs. Henry Ford could have persuaded Henry to install electric starters on all Model Ts in 1919.
