The Hunter Model T starter
Topic author - Posts: 778
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Has anyone see or used one of these?
Matt
I image they must not have been too good or we would see more.Matt
- First Name: Les
- Last Name: Schubert
Re: The Hunter Model T starter
I have one (at least the engine part). Haven’t installed it yet
- First Name: Matt
- Last Name: G
Wow LesLes Schubert wrote: ↑Tue Jun 23, 2020 2:11 pmI have one (at least the engine part). Haven’t installed it yet
Now your car is worth three times as much
Or at least when you get it working...
Matt!
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
I have one in a box. A local 14 roadster pickup has one. Thing is if it backfires while you a pull starting you may end up in front of the car! Just jokin'
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
- First Name: Tom
OOPS I have to take that back, I thought it was one of the pull starters that has a D shaped handle on the firewall for you to pull on.
- First Name: Susanne
- Last Name: Rohner
I actually had one on one of dad's cars years ago, but you need Schwarzenegger arms to pull it, or have cruddy compression. Unless you're relying on a hot engine and semi-free starts, that pull starter is NOT like starting your lawn mower, it's tough! WAY easier just to get out and crank it!
- First Name: Greg
- Last Name: Popove
How does it work?
Here's another version of pull chain mechanical starter from the dash.
Love the name......very appropriate.......think it would be a challenge to pull that handle sitting down behind the steering wheel
- First Name: William
- Last Name: May
Using this type of starter is no trouble at all!
You just get the mother-in-law to put the heave to it.
The only drawback I see is that since I paid $5 for the car in the first place, it's now only worth $15. That's kind of a disappointing return on investment. Plus, the thing itself cost me $4.75. So now the car is still worth only $10.25.
Well, $10.40, if you count the nickels I hammered in as freeze plugs.
- Last Name: May
Some of you guys are PRETTY extravagant!!!
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
In todays world, that add would most likely be open for a lawsuit. That doesn't look like a "self starter" to me.
Dave
1925 mostly original coupe.
I did a an internet search and found several similar devices marketed at that time. Some with good leverage for starting - not sure how they handled kick-back.
http://www.mtfca.com/discus/messages/11 ... 1288920924 Boston Starter http://www.mtfca.com/discus/messages/80 ... 1254274560 Nicely installed http://www.mtfca.com/discus/messages/80 ... 1246395151 http://www.mtfca.com/discus/messages/80 ... 1246395151
Jay in N California planning to install a Simplex starter it http://www.mtfca.com/discus/messages/118802/124401.html
The SANBO http://www.mtfca.com/discus/messages/59 ... 1455282622 Where Briggs & Stratton got the idea http://www.mtfca.com/discus/messages/118802/168184.html
- Last Name: Morsher
VARIATIONS- The Hunter Model T starter
Variations of same theme. I’m going to use the bottom one on a project, the top one is available to a tinkerer. I’ve seen a foot-lever-from-the-seat design that intrigues me. Two repaired shoulders here.
- First Name: Greg
- Last Name: Popove
I recommend Kickstarter. *chuckle*
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
I have a couple of different remote starters.
One is interesting in that it is a kick starter.
The starter is similar in shape to the existing pedals.
Makes the T a four pedal car!!
Can you post a photo, Harry?
- First Name: Greg
- Last Name: Popove
Something tells me that only Mrs. Henry Ford could have persuaded Henry to install electric starters on all Model Ts in 1919.
