The Hunter Model T starter
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Tue Jun 23, 2020 1:19 pm
Has anyone see or used one of these?
I image they must not have been too good or we would see more.
Matt
Les Schubert
First Name: Les
Last Name: Schubert
Re: The Hunter Model T starter
Post by Les Schubert » Tue Jun 23, 2020 2:11 pm
I have one (at least the engine part). Haven’t installed it yet
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Tue Jun 23, 2020 2:32 pm
Wow Les
Now your car is worth three times as much :lol:
Or at least when you get it working...
Matt!
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Tue Jun 23, 2020 2:44 pm
I have one in a box. A local 14 roadster pickup has one. Thing is if it backfires while you a pull starting you may end up in front of the car! Just jokin'
tom_strickling
Post by tom_strickling » Tue Jun 23, 2020 2:46 pm
OOPS I have to take that back, I thought it was one of the pull starters that has a D shaped handle on the firewall for you to pull on.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Tue Jun 23, 2020 6:24 pm
I actually had one on one of dad's cars years ago, but you need Schwarzenegger arms to pull it, or have cruddy compression. Unless you're relying on a hot engine and semi-free starts, that pull starter is NOT like starting your lawn mower, it's tough! WAY easier just to get out and crank it!
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Tue Jun 23, 2020 7:25 pm
How does it work?
Post by DanTreace » Tue Jun 23, 2020 7:55 pm
Here's another version of pull chain mechanical starter from the dash.
Love the name......very appropriate.......think it would be a challenge to pull that handle sitting down behind the steering wheel :lol:
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jun 23, 2020 8:03 pm
Using this type of starter is no trouble at all!
You just get the mother-in-law to put the heave to it.
The only drawback I see is that since I paid $5 for the car in the first place, it's now only worth $15. That's kind of a disappointing return on investment. Plus, the thing itself cost me $4.75. So now the car is still worth only $10.25.
Well, $10.40, if you count the nickels I hammered in as freeze plugs.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jun 23, 2020 8:05 pm
Some of you guys are PRETTY extravagant!!!
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Wed Jun 24, 2020 5:27 am
In todays world, that add would most likely be open for a lawsuit. That doesn't look like a "self starter" to me. :roll: Dave
1925 mostly original coupe.
Post by TRDxB2 » Wed Jun 24, 2020 10:56 am
I did a an internet search and found several similar devices marketed at that time. Some with good leverage for starting - not sure how they handled kick-back.
http://www.mtfca.com/discus/messages/11 ... 1288920924
Boston Starter http://www.mtfca.com/discus/messages/80 ... 1254274560
Nicely installed http://www.mtfca.com/discus/messages/80 ... 1246395151 http://www.mtfca.com/discus/messages/80 ... 1246395151
Jay in N California planning to install a Simplex starter it http://www.mtfca.com/discus/messages/118802/124401.html
The SANBO http://www.mtfca.com/discus/messages/59 ... 1455282622
Where Briggs & Stratton got the idea http://www.mtfca.com/discus/messages/118802/168184.html
Dropacent
Last Name: Morsher
VARIATIONS- The Hunter Model T starter
Post by Dropacent » Wed Jun 24, 2020 1:38 pm
Variations of same theme. I’m going to use the bottom one on a project, the top one is available to a tinkerer. I’ve seen a foot-lever-from-the-seat design that intrigues me. Two repaired shoulders here.
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Jun 26, 2020 10:23 am
I recommend Kickstarter. *chuckle*
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Fri Jun 26, 2020 7:46 pm
I have a couple of different remote starters.
One is interesting in that it is a kick starter.
The starter is similar in shape to the existing pedals.
Makes the T a four pedal car!!
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Jun 27, 2020 12:27 pm
Can you post a photo, Harry?
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Sat Sep 19, 2020 3:26 pm
Something tells me that only Mrs. Henry Ford could have persuaded Henry to install electric starters on all Model Ts in 1919.
