Cotter pins tips
Topic author - Posts: 29
- Last Name: Mosher
- MTFCA Number: 49626
Cotter pins tips
I wish I could have been at Ford factory to watch the cotter pin man bend those dam pins!! It’s been years and I’m still fighting with cotter pins. Especially removing them. Can anyone sheer any tips? On installing and removing.
Re: Cotter pins tips
Whether or not, I don't know. But the way I install them is to put the head in the slot of the castle nut facing up and down the bolt. Then I bend one end, up over the end of the bolt. I snip off the other end about 3/8inch sticking out and bend it toward the nut. To remove them, I snip off the head and pull out the ends from the end opposite the head.
For clevis pins, I install the cotter pin with the head parallel to the clevis and bend both ends around the pin.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
For removal, I straighten out the ends as much as possible, insert one jaw of a pair of needle nose pliers into the loop, close the jaws to clamp onto the loop, and pry or if necessary hammer on the pliers.
I straighten the ends as much as possible and then use a pair of side cutters to grip the loop. The cutters are used to lever against the side of the nut so I am not using a straight out pull that can let go in a hurry. That way I don't bash my elbow/hands/T with a sudden let-go.
- First Name: Henry
- Last Name: Petrino
I don't think the cotter pin guy at the Ford factory removed very many cotter pins.
- Last Name: Branigan
The early automobile pins are a bit harder to come buy or make as the Eye is round and the ends are the same length. Making them much harder to get a hold of to bend over. On the newer pins that most are use to that are in a tight spot I take a flat blade screw driver and cut a slot in the end of it then slip it over the tab and bend it.
- Last Name: House
- MTFCA Number: 115
Depends on what cotter pins you’re removing. When removing the 3 cotter pins holding the 3 set screws on the high speed adjustment ‘fingers’, I think the most important ‘tool’ is paper towels-not cotton rags w/ lint- very carefully placed in the tranny on each side of the cotter pin to be removed. Then, taking a deep breath and holding my tongue just right, I straighten the legs of the pin and pull the loop out with needle nose pliers.
One of the biggest problems with today’s youth is they’ve never known the fear of hearing leather being rapidly pulled through seven Wrangler belt loops.
- First Name: William
- Last Name: May
If you buy a cotter-pin extractor, especially one from Snap-On, you can have them out in 1 second, whether or not you straighten the ends. I've been using one for 40 years on aircraft. There is no argument or hesitation or fuss. No blood and no small cut off parts to retrieve.
That is also the way I do it.Allan wrote: ↑Tue Oct 06, 2020 5:20 pmI straighten the ends as much as possible and then use a pair of side cutters to grip the loop. The cutters are used to lever against the side of the nut so I am not using a straight out pull that can let go in a hurry. That way I don't bash my elbow/hands/T with a sudden let-go.
1920 Dodge touring
1920 Dodge touring
George, you reminded me of a different way I remove those 3 pins. Because they are free to move about in their application, the legs are often worn where they move. I grab that end with some long nosed lock-on pliers before straightening them. Often they break off, and the pliers have the bit held captive.
- MTFCA Number: 16175
- MTFCI Number: 14758
I use stainless. No rust. Some claim they're harder to remove than steel, but they seem about the same to me.
I was the one who bought them, so they can't be terribly expensive.
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
I've posted this in the past but here it is again. Found at a garage sale most likely. Jim
- Last Name: Mosher
That’s a great for pins.
I Magine they are scarce
Where can I find one of those?
- Last Name: Warren
Bill, can you post a photo of the snap on one? Craftsman use to have one that looked like a bent awl. The one Jim posted is interesting, and looks like it could be effective. I also usually use side cutters. I really like Steve's ss pins.
Here are photos of my Craftsman extractor. I hardly ever use it, I usually use the needle nose pliers first.
- Last Name: Warren
A friend that installed windshields always called that one a window installation tool! HA HA Anyway it worked well with the rubber.
- MTFCA Number: 14972
- MTFCI Number: 15411
I also have a Craftsman puller as shown - depending where on the T that I'm working, my dykes (side-cutter apparently is the proper term ?) pulls most all of them.
I put a needle nose pliars through the eye and roll it against the nut for leverage.
- First Name: Dick
- Last Name: Fischer
A lot of good tools and methods here. I have most of the tools shown and have used all of the methods at one time or another. If one tool/method doesn't work, try one of the others.
The only thing I have to offer that's different is to grind the flat side of a pair of side-cutters down until the cutting edge is nearly flush in order to get hold of the head when it's nearly flush with the slot of the castle nut. Be careful to not overheat the cutters while grinding -- you don't want to soften the cutting edge.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
I assume we are talking about cotter pins someone else installed? The thing to remember is cotter pins don't realy keep nuts from coming loose. They keep them from falling off. Wrapping them around around the nut is not nessessary. They only need to be bent enough to keep the pin from falling out.
All the tools mentioned are great to solve the problem of people trying to hold bolts tight. Do your self a faver and don't fallow their example, keep it simple. You are probably going to be the next one to work on it.
I too bend one leg up over the end of the bolt, and one end down the side of the nut. I can't imagine that much effort went into doing it this way on the production line. I believe on engines both legs of the pins were bent down, about 45 degrees. It makes sense, just dong the pin with a hammer/tool of choice, job done.
- First Name: Jim
- Last Name: Riedy
I should mention that tool I posted works well on newer or recent applications but if your working on something that has not been apart in 100 years or so they won't come out so easy. This is what I have had good luck with, I just back the nut that I'm working on off shearing the cotter off then I take a small drift and drive out the remaining parts of the pin, the remains usually show up as shiny metal against a rusty background. Jim
- First Name: Mike
- Last Name: Sleep
- MTFCA Number: 31639
- MTFCI Number: 31639
Are there any manufacturer markings on your old tool? Wondering who made it. It would be a neat conversation piece if you never used it.
- First Name: Jim
- Last Name: Riedy
Mike, I finally dug it out haven't used it in awhile, it is made in USA and named Zim cotter pin puller. It looks as if it may have been plated at one time. Jim
