A different oil pump option
Topic author - Posts: 1359
- First Name: Les
- Last Name: Schubert
Using a flathead V8 oil pump. To alleviate any confusion about oiling the transmission, the transmission shaft has a hole down the center and a side hole and is fed from the rear main bearing. I first used this concept over 40 years ago and it worked great!
- First Name: Les
Re: A different oil pump option
I had to extend the back of the camshaft about one and a half inches.
I figure the advantage is that priming the oil pump is longer a issue as the pump is immersed in the oil!!
- First Name: Henry
- Last Name: Lee
Going back to what really works or known! Looks good Les.
The VW pumps were meant to be submerged not elevated as most do..., we had a lot of them fail. Only gear driven for us.
My $0.03
Hank
My $0.03
Hank
- First Name: Les
Hank
I interested in the system you describe. Please provide some more information??
My experience with the VW is that I ALWAYS “blip” the throttle immediately on start up and then it worked OK. Now I’m trying to make it more “idiot proof “ so my heirs can have fun with it!!
Is there still room for a flywheel in there?
- First Name: Les
Yes the flywheel fits just fine!!
Beautiful workmanship, as always!
- First Name: Henry
- Last Name: Lee
Les I am currently using the generator well drive via a Datsun B210 pump. But in the future, going to build a side drive for that pump in a different location to give more options. Really busy with other things currently.
Hank
Hank
- First Name: Les
Years ago I thought about building a drive adapter that fit in there with the generator behind it with the idea of mounting the oil pump below it. Also considered the “dry sump” concept.
- First Name: Henry
- Last Name: Lee
You and I are on the same page Les.
- First Name: Tony
- Last Name: Bowker
I guess that the aluminum cylinder with the hole is the pickup and I believe I can see a filter inside.a couple of questions which I suspect many would like to know more details.
Is the pump as low as the pan will allow?
How did you connect the gear to the rear of the camshaft?
How does the oil that accumulates behind the shield get back to the pump side of the shield?
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Les
Yes the aluminum cylinder with the screen is the oil “pickup”
The elevation of the pump is a function of the location of the camshaft and the length of the oil pump, so I really have no decision there.
The oil pickup I located to a “practical” location low in the pan.
The camshaft extension is by drilling a 1/2” hole about a inch into the end and making a piece of 3/4” bar that is about.0015” interference and with some heat and pressure it is now locked in place. Then when cool, machine to 5/8” to fit the gear, a woodruff key and a snap ring.
The gear is installed when the camshaft is in place.
Hopefully this helps.
- First Name: Les
The “flywheel windage tray” concept I first used in the ‘70’s and it has worked great. Part of it is the drilled transmission shaft. I have installed a small spray nozzle above the bands.
This engine is getting a era accessory 3 speed sliding gear transmission, so some of that lubrication is yet to be designed!!
- First Name: Les
This is the gear I use for the camshaft.
A Boston H1012L. 10 pitch 12 tooth Left hand
- First Name: Les
Made good progress on a second one. I realized I had the pump, the gear and a “home” for it!!
- First Name: Tony
- Last Name: Bowker
Thanks Les for some more details. The ingenuity of machinists always amazes me.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Les
And here is the camshaft extended and the gear on it. The extension is threaded in with a LH thread
- First Name: Henry
- Last Name: Lee
Pretty Slick Les! I like it!
Hank
Hank
- Last Name: Warren
Love the build Les. Keep at it ! jw
