An idea I tried today
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 20, 2020 4:26 pm
It is inevitable that when line boring blocks that you will have a “gosh dang” experience. And you end up with one bearing that needs to be “fixed”!!
So I had a centre main cap that I was not happy with the adherence of the babbit. I have 5 good surfaces and 1 that I decided to redo.
So now the struggle is how to realign everything.
I had a moment of inspiration and mentioned it to a friend and he said he had successfully used the same concept.
So here are some pictures of the process this morning. This engine has a “C” crank cut to standard A size and full pressure.
Les Schubert
First Name: Les
Last Name: Schubert
Re: An idea I tried today
Post by Les Schubert » Fri Nov 20, 2020 4:34 pm
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 20, 2020 4:37 pm
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 20, 2020 4:40 pm
And here is the cap to bore
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Fri Nov 20, 2020 7:00 pm
Les:
i have bored the babbitt lined inserts of the 5 mainbearing Dodge Brothers 4 cyl. engines by placing bronze bushings in the #2 and #4 mainbearing saddle in the block and the inserts in the center mainbearing saddle ... worked great ... always an optimist ...Gene French
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Nov 28, 2020 5:50 pm
So got the line boring done today. Re aligned within about.001”!!
John Warren
Last Name: Warren
Post by John Warren » Sun Nov 29, 2020 10:16 am
Good deal, thanks for sharing!! jw
