An idea I tried today
Topic author - Posts: 1359
- First Name: Les
- Last Name: Schubert
It is inevitable that when line boring blocks that you will have a “gosh dang” experience. And you end up with one bearing that needs to be “fixed”!!
So I had a centre main cap that I was not happy with the adherence of the babbit. I have 5 good surfaces and 1 that I decided to redo.
So now the struggle is how to realign everything.
I had a moment of inspiration and mentioned it to a friend and he said he had successfully used the same concept.
So here are some pictures of the process this morning. This engine has a “C” crank cut to standard A size and full pressure.
- First Name: Les
- First Name: Les
- First Name: Les
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Re: An idea I tried today
Les:
i have bored the babbitt lined inserts of the 5 mainbearing Dodge Brothers 4 cyl. engines by placing bronze bushings in the #2 and #4 mainbearing saddle in the block and the inserts in the center mainbearing saddle ... worked great ... always an optimist ...Gene French
- First Name: Les
So got the line boring done today. Re aligned within about.001”!!
- Last Name: Warren
Good deal, thanks for sharing!! jw
