A different oil pump option
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 27, 2020 1:41 pm
Using a flathead V8 oil pump. To alleviate any confusion about oiling the transmission, the transmission shaft has a hole down the center and a side hole and is fed from the rear main bearing. I first used this concept over 40 years ago and it worked great!
Les Schubert
First Name: Les
Last Name: Schubert
Re: A different oil pump option
Post by Les Schubert » Fri Nov 27, 2020 1:44 pm
I had to extend the back of the camshaft about one and a half inches.
I figure the advantage is that priming the oil pump is longer a issue as the pump is immersed in the oil!!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 27, 2020 2:03 pm
Going back to what really works or known! Looks good Les.
The VW pumps were meant to be submerged not elevated as most do..., we had a lot of them fail. Only gear driven for us.
My $0.03
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 27, 2020 2:17 pm
Hank
I interested in the system you describe. Please provide some more information??
My experience with the VW is that I ALWAYS “blip” the throttle immediately on start up and then it worked OK. Now I’m trying to make it more “idiot proof “ so my heirs can have fun with it!!
Post by Jerry VanOoteghem » Fri Nov 27, 2020 2:51 pm
Is there still room for a flywheel in there?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 27, 2020 3:19 pm
Yes the flywheel fits just fine!!
Post by Jerry VanOoteghem » Fri Nov 27, 2020 6:12 pm
Beautiful workmanship, as always!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 27, 2020 7:51 pm
Les I am currently using the generator well drive via a Datsun B210 pump. But in the future, going to build a side drive for that pump in a different location to give more options. Really busy with other things currently.
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Nov 27, 2020 10:06 pm
Years ago I thought about building a drive adapter that fit in there with the generator behind it with the idea of mounting the oil pump below it. Also considered the “dry sump” concept.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Nov 27, 2020 10:10 pm
You and I are on the same page Les.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Fri Nov 27, 2020 11:30 pm
I guess that the aluminum cylinder with the hole is the pickup and I believe I can see a filter inside.a couple of questions which I suspect many would like to know more details.
Is the pump as low as the pan will allow?
How did you connect the gear to the rear of the camshaft?
How does the oil that accumulates behind the shield get back to the pump side of the shield?
Tony Bowker
La Mesa, California
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Nov 28, 2020 11:24 am
Yes the aluminum cylinder with the screen is the oil “pickup”
The elevation of the pump is a function of the location of the camshaft and the length of the oil pump, so I really have no decision there.
The oil pickup I located to a “practical” location low in the pan.
The camshaft extension is by drilling a 1/2” hole about a inch into the end and making a piece of 3/4” bar that is about.0015” interference and with some heat and pressure it is now locked in place. Then when cool, machine to 5/8” to fit the gear, a woodruff key and a snap ring.
The gear is installed when the camshaft is in place.
Hopefully this helps.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Nov 28, 2020 11:28 am
The “flywheel windage tray” concept I first used in the ‘70’s and it has worked great. Part of it is the drilled transmission shaft. I have installed a small spray nozzle above the bands.
This engine is getting a era accessory 3 speed sliding gear transmission, so some of that lubrication is yet to be designed!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Nov 29, 2020 5:39 pm
This is the gear I use for the camshaft.
A Boston H1012L. 10 pitch 12 tooth Left hand
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Nov 29, 2020 6:51 pm
Made good progress on a second one. I realized I had the pump, the gear and a “home” for it!!
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Sun Nov 29, 2020 9:17 pm
Thanks Les for some more details. The ingenuity of machinists always amazes me.
Tony Bowker
La Mesa, California
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Dec 04, 2020 7:20 pm
And here is the camshaft extended and the gear on it. The extension is threaded in with a LH thread
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Dec 04, 2020 9:16 pm
Pretty Slick Les! I like it!
Hank
John Warren
Last Name: Warren
Post by John Warren » Fri Dec 04, 2020 9:28 pm
Love the build Les. Keep at it ! jw
