Hot Air Pipe
TBill
First Name: Bill
Last Name: Obier
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 TT, 1913 Speedster (WIP)
Hot Air Pipe
Post by TBill » Mon Dec 21, 2020 6:45 am
I bought a new hot air pipe from Lang’s for my 26 Fordor and can’t seem to make it fit. Looks like I will need to modify it to make it work. Fits “OK” with the exhaust/intake manifold clamp on #4 removed but can’t get it to fit otherwise.
The hot air pipe on my 26 TT is a somewhat different design.
Anyone else ever have this problem?
Last Name: Strange
Re: Hot Air Pipe
Post by CudaMan » Mon Dec 21, 2020 7:11 am
I have not had good results with the reproduction hot air pipes. The originals aren't that hard to find, check on Ebay or post a wanted ad on the Classifieds. Your '26 should have the one-piece pipe as shown here:
Re: Hot Air Pipe
Post by Original Smith » Mon Dec 21, 2020 10:18 am
The late '25s use the swivel adjustment too, but don't require the relief in the hot air pipe, but I have one on my car anyway. I agree, stay away from the repro hot air pipes, there are too many originals around.
Re: Hot Air Pipe
Post by TRDxB2 » Mon Dec 21, 2020 12:37 pm
Lengthy discussion about Hot Air Pipe fitments https://mtfca.com/phpBB3/viewtopic.php? ... pe#p117896. Note what was said above and the differences also what you bought and what your putting it on. Not sure what yours looks like so.....
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Hot Air Pipe
Post by Dan McEachern » Tue Dec 22, 2020 2:15 am
J1MGolden
Last Name: Golden
Re: Hot Air Pipe
Post by J1MGolden » Tue Dec 29, 2020 3:03 pm
The early new one will work.
It is just a case of cut to specification, pound to fit, and paint to match.
The top area has to be pounded in about 1/4 to 3/8th inch in line with the choke/ mixture rod (as Mark's photo shows), and the hole for the exhaust clamp has to be cut out more on the bottom or top, I forget which way, but then it will work OK, and last a long time.
