I bought a new hot air pipe from Lang’s for my 26 Fordor and can’t seem to make it fit. Looks like I will need to modify it to make it work. Fits “OK” with the exhaust/intake manifold clamp on #4 removed but can’t get it to fit otherwise.
The hot air pipe on my 26 TT is a somewhat different design.
Anyone else ever have this problem?
Hot Air Pipe
- Last Name: Strange
Re: Hot Air Pipe
I have not had good results with the reproduction hot air pipes. The originals aren't that hard to find, check on Ebay or post a wanted ad on the Classifieds. Your '26 should have the one-piece pipe as shown here:
Re: Hot Air Pipe
The late '25s use the swivel adjustment too, but don't require the relief in the hot air pipe, but I have one on my car anyway. I agree, stay away from the repro hot air pipes, there are too many originals around.
Re: Hot Air Pipe
Lengthy discussion about Hot Air Pipe fitments https://mtfca.com/phpBB3/viewtopic.php? ... pe#p117896. Note what was said above and the differences also what you bought and what your putting it on. Not sure what yours looks like so.....
- First Name: DAN
- Last Name: MCEACHERN
- Last Name: Golden
Re: Hot Air Pipe
The early new one will work.
It is just a case of cut to specification, pound to fit, and paint to match.
The top area has to be pounded in about 1/4 to 3/8th inch in line with the choke/ mixture rod (as Mark's photo shows), and the hole for the exhaust clamp has to be cut out more on the bottom or top, I forget which way, but then it will work OK, and last a long time.
