Oil Slingers- Yay or Nay?
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Fri Jan 08, 2021 1:01 pm
Building an engine with an external mag and I have found some competing info on the forum concerning slingers. What do you think?
Re: Oil Slingers- Yay or Nay?
Post by Rich Eagle » Fri Jan 08, 2021 1:09 pm
I have driven my Speedster for 40 some years without them. If I had the engine apart today I would add some. They can't hurt but mine has done fine without them for 15-20,000 miles.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Jan 08, 2021 3:56 pm
I have tore several engines down that did not have them and the wrist pins where blued from not enough oil getting to them.
Last Name: Hatch
Post by Dan Hatch » Fri Jan 08, 2021 4:22 pm
If you are removing magnets you should look into a ring to keep the triple gear pins from backing out. The magnets do this when they are there. I have not had any back out, but have heard of them doing it. Dan
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Jan 08, 2021 4:48 pm
Here is what Dan is referring to. Also a different version of oil slingers that work quite well.
Been using these for years and I moved away from simply using spools and bolts to insure good oil circulation for both the engine and transmission. The ring might be a belt and suspenders approach for the triple gear pins, but its hardly worth the risk anymore in my opinion. From other postings regarding flywheel balancing, this is a pretty typical balance correction, and this is on a later fully machined style flywheel.
Post by Mark Gregush » Fri Jan 08, 2021 6:16 pm
Nice! While I was reading this I was wondering who came up with only 4 paddles, thinking it would throw things off, then Dan shows the above. (I am not talking about a balancing the flywheel)
Last Name: Hatch
Post by Dan Hatch » Fri Jan 08, 2021 6:25 pm
That is what I am talking about.
