Support Forum
mt15
- First Name: gary
- Last Name: griffin
Post
by mt15 » Tue Jan 12, 2021 4:06 pm
Pratt Lampert Cherry Bark stain was discontinued 2 years ago. I just found out when I went to purchase some for my latest project. This is the closest color to the original used on early Ford firewalls.
I know of at least 4 Stynoski winning cars that used this stain.
I live in the sticks and a local hardware store has 4 quarts left. They had 5
I will gladly pick up the rest and ship at my cost.
Gary
Kbillet
- First Name: Keith
- Last Name: Billet
Post
by Kbillet » Tue Jan 12, 2021 4:57 pm
I would like a quart.
I sent an email with my phone no.
Keith Billet
mt15
- First Name: gary
Post
by mt15 » Tue Jan 12, 2021 5:00 pm
I set one aside.
Just noticed I posted Cheery instead of Cherry Bark!!!!
Don't know how to change it. Oh well that should get a few chuckles.
Gary
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Post
by Mike Lebsack-Iowa » Tue Jan 12, 2021 6:11 pm
Hi Gary,
I would like one quart as well. I will send you an email. Mike Lebsack
It's Bill
- First Name: Bill
- Last Name: Hoffer
Post
by It's Bill » Tue Jan 12, 2021 8:52 pm
Hi Gary, please reserve one for me. I will pm you with my contact info and to get you paid. Cheers, Bill
It's Bill
- First Name: Bill
- Last Name: Hoffer
Post
by It's Bill » Tue Jan 12, 2021 9:11 pm
Gary, I had to send an email. I could not figure out how the pm messaging works. Duh, Bill
Post
by TWrenn » Wed Jan 13, 2021 10:35 am
Laurel Mountain Forge Cherry stain is also "cheery", and from comparison pics to original stained firewalls, comes about
as close as it gets too. Certainly, it worked for my '13 to achieve the "Gold" award back in 2016. The 4 oz. bottle will easily do two firewalls. A quart of stain would problably do 60 cars!!
Post
by Original Smith » Wed Jan 13, 2021 10:56 am
I recently restored a 1913 KW coilbox, and used the Cherry Bark stain. It is beautiful, BUT, I think the Laurel Mountain Forge stain is closer to the original, and it is still available.
Ray Syverson
- First Name: Ray
- Last Name: Syverson
- * REQUIRED* Type and Year of Model Ts owned: 1913 Depot Hack
- Board Member Since: 2010
Post
by Ray Syverson » Wed Jan 13, 2021 1:50 pm
I truly think that the cherry firewalls were hosed down with a heavily pigmented stain, almost like a paint, then brushed and let dry before they were coated with shellac. It would have been an easy way to get consistent looking finishes on the. firewalls. I have this original 1913 firewall that I rubbed the finish off using denatured alcohol.
Post
by TWrenn » Wed Jan 13, 2021 7:32 pm
I'll play salesman here for Laurel Mountain Forge's cherry stain...here's my '13 after I replaced her firewall and stained it with the L.M. stain. Like Larry said, it's about as close to the real thing as it gets. And yep, the pin stripes are "One-Shot" medium grey which from tons of research are also about as close as it gets. It mostly looks white in a lot of light, in the barn the grey comes through.
Larry
- Last Name: Gresh
Post
by Larry » Wed Jan 13, 2021 9:49 pm
Here is a close up of a 1910 firewall that I did with Laurel Mountain Forge Cherry on the correct cherry Veneered firewall.
It’s a beautiful stain and I agree with you Tim probably very close to the original color.
Post
by TWrenn » Thu Jan 14, 2021 3:38 pm
Larry...ha ha, yeh our two firewalls look remarkably similar in color!
George Mills
- Last Name: Mills
Post
by George Mills » Thu Jan 14, 2021 5:24 pm
Ray S.
When you did the denatured alcohol on the original finish...did it lift immediately to bare wood? Or did you have to do it over and over and scrub thru a sticky mess?
If it simply lifted to bare wood almost immediately...then the original firewall you have was never stained, but rather a shellac wash with red pigment suspended in it. The actual first coat may have been a spit shellac also. Not to take away from what others have done on their own restoration...but for a future purist, knowing that it was a surface finish and not a penetrating finish might help with a material decision?
Post
by Original Smith » Fri Jan 15, 2021 9:43 am
BTW, I believe the correct name is Pratt and Lambert.
