Mercury drop axle
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Mercury drop axle
Post by Philip Lawrence » Thu Jan 14, 2021 4:08 pm
What was the amount of drop on an original Mercury axle?
AndyClary
First Name: Andrew
Last Name: Clary
Re: Mercury drop axle
Post by AndyClary » Fri Jan 15, 2021 12:24 am
Mine looks to be 3 inches.
Andy
Post by TRDxB2 » Fri Jan 15, 2021 2:37 am
Many pictures of Merc speedsters Picture 1 shows rear drop
https://public.fotki.com/thenewcityfami ... html#media
Post by Wayne Sheldon » Fri Jan 15, 2021 3:22 am
Looks about the bottom of the axle to the bottom of the spring perch bushing.
Post by Original Smith » Fri Jan 15, 2021 9:41 am
Check with Jarvis Erickson. He knows more about Mercury's than anyone.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Fri Jan 15, 2021 10:39 am
All I have is a Mercury and a tape measure.
Andy
Post by TRDxB2 » Fri Jan 15, 2021 12:12 pm
Andy
Andy
My apologizes for jumping in after your first entry - didn't realize then that you measured it :oops:
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jan 15, 2021 2:11 pm
I thought it was 4” , Andy. Measuring mine confirmed that. I did flunk math, so you might want to double check.
Perry Goble
First Name: William
Last Name: Goble
Post by Perry Goble » Fri Jan 15, 2021 4:41 pm
The Vintage Ford July / August 1980 Page 13 has a original ad stating that the Henry Vogt drop forging lowering the body to a nine inch road clearance .Page 7 and 9 1924 Vogt Mercury script , four- inch - dropped front axles .
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Fri Jan 15, 2021 6:04 pm
My mistake, I measured the axle itself which was 3 inches. The Ford axle actually drops at the fork so the effective drop will be more.
Andy
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Jan 15, 2021 6:46 pm
If anyone has an extra laying in the corner, I would gladly consider discussing a change of ownership!
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Fri Jan 15, 2021 8:12 pm
So did they have a 4 inch drop?
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Post by Tim Moore » Fri Jan 15, 2021 8:59 pm
Yes 4" lowered with front axle and frame package. It is in the advertising and I own Mercury #139.
Tim Moore
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Fri Jan 15, 2021 10:46 pm
Thanks to all who responded to my inquiry.
Tbz4u
Last Name: Weitzel
* REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
Post by Tbz4u » Wed Jan 20, 2021 10:48 pm
Hey Phil if you like to co.e by and see my mercury just call its the yellow one I. Pictures above bring your mask and tape measure Robert@aaglassshop.com
