Mercury drop axle
Philip Lawrence
Topic author - Posts: 501
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
Mercury drop axle
What was the amount of drop on an original Mercury axle?
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Mercury drop axle
Mine looks to be 3 inches.
Andy
Andy
Many pictures of Merc speedsters Picture 1 shows rear drop
https://public.fotki.com/thenewcityfami ... html#media
Looks about the bottom of the axle to the bottom of the spring perch bushing.
Check with Jarvis Erickson. He knows more about Mercury's than anyone.
AndyClary
- Last Name: Clary
All I have is a Mercury and a tape measure.
Andy
Andy
My apologizes for jumping in after your first entry - didn't realize then that you measured it
Dropacent
- Last Name: Morsher
I thought it was 4” , Andy. Measuring mine confirmed that. I did flunk math, so you might want to double check.
Perry Goble
- First Name: William
- Last Name: Goble
The Vintage Ford July / August 1980 Page 13 has a original ad stating that the Henry Vogt drop forging lowering the body to a nine inch road clearance .Page 7 and 9 1924 Vogt Mercury script , four- inch - dropped front axles .
AndyClary
- Last Name: Clary
My mistake, I measured the axle itself which was 3 inches. The Ford axle actually drops at the fork so the effective drop will be more.
Andy
Andy
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
If anyone has an extra laying in the corner, I would gladly consider discussing a change of ownership!
Philip Lawrence
So did they have a 4 inch drop?
Tim Moore
- First Name: TIMOTHY
- Last Name: MOORE
- * REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Yes 4" lowered with front axle and frame package. It is in the advertising and I own Mercury #139.
Tim Moore
Tim Moore
Philip Lawrence
Thanks to all who responded to my inquiry.
Tbz4u
- First Name: Robert
- Last Name: Weitzel
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
Hey Phil if you like to co.e by and see my mercury just call its the yellow one I. Pictures above bring your mask and tape measure Robert@aaglassshop.com
