Questions about valve lifter rotation...
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Thu Sep 09, 2021 6:10 pm
Are Model T valve lifters are intended to rotate while the engine is running?
If so, are new lifters crowned slightly and the cam lobes tapered slightly to encourage this rotation?
Are Model T engines designed with an offset between lifter bore and cam lobes?
The following diagram from Crane Cams suggests offset bore and lobe are required for lifters to rotate.
Thank you.
Re: Questions about valve lifter rotation...
Post by Scott_Conger » Thu Sep 09, 2021 6:33 pm
T lifters will do what they will do
My opinion is that no one is selling a lifter which is useable out of the box. They all need to be butt-ground before being put into service.
Herm Konkhe was a huge proponent of it and can be found here: https://mtfca.com/phpBB3/viewtopic.php?t=1081
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Sep 09, 2021 6:38 pm
By design at that time, I say no but the lifters do rotate some but only because nothing is completely machined to "0"
