front fender brace mounting
Alden
First Name: Bob
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by Alden » Tue Sep 21, 2021 2:28 pm
I can't figure out how to post a picture, but I saw one of a brace the had two bump outs for the headlights. How do they mount, use existing riveted holes replaced by bolts or would you have to drill holes, (I wouldn't)
Re: front fender brace mounting
Post by TXGOAT2 » Tue Sep 21, 2021 3:27 pm
Do you have a '26-27 car and a Ford headlight bar, or is it anaftermarket brace or older car?
Alden
First Name: Bob
Post by Alden » Tue Sep 21, 2021 3:41 pm
I should have said: It's a 1922 touring car.
Post by Norman Kling » Tue Sep 21, 2021 4:29 pm
The only one with lights on the bar, I know of was for a 1927 "improved" T. Any others made for older T's would be an aftermarket accessory and would only support the fenders and use the standard headlights.
Alden
First Name: Bob
Post by Alden » Tue Sep 21, 2021 6:28 pm
I wish I could post a picture. the bar goes from fender to fender and has bump ins to go behind the light and then straight and bumps in around the back of the other headlight and on to the fender. The bumps bypass the lights , it has nothing to do with mounting of the head lights.
Last Name: Seth
Post by perry kete » Tue Sep 21, 2021 7:02 pm
Alden,
Go to the board index and click on the "Support" heading then scroll down to the topic of "Photo frustration" Mr. Steve Jelf has posted on there detailed instructions on how to post photos on this site.
Last Name: Kuehn
Post by John kuehn » Tue Sep 21, 2021 7:13 pm
It sounds like your describing a fender brace that was added to it. Fender braces were used pretty often on T’s as they got older to keep the fenders from sagging. People would haul this and that between the hood and fenders and people would take a ride and sit on the fenders. Then the fenders started dropping. There were several different style braces that were used. Yours is one of them.
Last Name: Gregush
Post by Mark Gregush » Tue Sep 21, 2021 8:04 pm
Without pictures, this will be tough. Most fender braces go in front of headlights from side to side, not back around them. The more common ones, have a clip that attaches to the outside of the fender edge, with a brace rod/bar in between. This maybe; http://www.mtfca.com/discus/messages/70 ... 1484946183
Go down to Jan 20, 10:01 am post. I sent a note to Dan, maybe he can helpl
Post by DanTreace » Tue Sep 21, 2021 8:14 pm
If you mean this type, ARG fender iron brace, the castings at each end have holes that are located over the two rivet heads to the fender/bracket. You chip off the ends of the rivets, drive them out, then place the brace over the holes. Secure with carriage head bolts on top, and lock washers and nuts under. The carriage bolt heads look like rivets.
Alden
First Name: Bob
Post by Alden » Tue Sep 21, 2021 8:25 pm
That is it ! So no new holes have to be drilled. Excellent thank you all. Now I just have to find one.
Last Name: Gregush
Post by Mark Gregush » Tue Sep 21, 2021 8:34 pm
Great and thank you Dan!
Last Name: Kuehn
Post by John kuehn » Tue Sep 21, 2021 9:44 pm
The follow up pics of all the fender braces are pretty neat! I’ve never seen the setup that Dan pictured. Not that it means anything but those look pretty neat in my opinion. Finding braces like that might not be easy. Their another T item that was thrown away because people didn’t know what was it for when piling up scrap iron and metal for farm auctions and cleaning up old junk iron.
Post by DanTreace » Wed Sep 22, 2021 8:52 am
John
Agree, hard to find the ARG brand, these were made in Birmingham AL, perhaps had national sales, but likely found in the southeast.
I got the one for the '23 cut off barn T from Dan Hatch, who lives in Birmingham, perhaps he could round up another. ;)
And, they made a Rear Fender brace.
Have a buddy in GA who has this Right hand brace, but needs a Left hand one too.....that rear brace will have the same markings but a "L" in the casting letters on the mounting leg.
ARG Rear
Looking for this style But with an "L" in the casting, not the R in this photo.
Last Name: Wrenn
Post by TWrenn » Wed Sep 22, 2021 11:37 am
Wow, how different! Never seen one before. Learn something new every day. Thanks Dan!
