Valve Cover 1927
Greg sarky k
First Name: Gregory
Last Name: Kojoyian
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo,1912 Touring,1912 Torpedo ,1913 Touring
Valve Cover 1927
Post by Greg sarky k » Wed Nov 03, 2021 6:30 pm
What is the correct color for valve covers in 1927?
Greg
Last Name: House
Re: Valve Cover 1927
Post by George House » Wed Nov 03, 2021 7:21 pm
...engine color
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Nov 03, 2021 9:05 pm
In general, for 26-27, cast parts are moleskin, stamped parts are black.
J1MGolden
Last Name: Golden
Post by J1MGolden » Sat Nov 06, 2021 6:46 pm
I have always wondered about that or what color moleskin is, as I have never seen a green mole.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sat Nov 06, 2021 6:55 pm
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Nov 06, 2021 10:36 pm
Does the MTFCA Encyclopedia give this information? Painting the stamped steel parts a different color than the cast parts' color, would certainly set them off, but I can't believe Henry Ford would put that expense into a Model T engine. It took him 18 years, just to change the head bolts and some other engine hardware from painted to nickle plated.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Nov 07, 2021 7:28 am
There was so many sheet metal parts made and it came down the line for 24-5 they got throwed on a 26-7 to use them up so it was not taking more time he was using up old parts. I have seen on original cars a 13 front fender on a 14 and the other side being a 14 fender, it does not take much to notice a body line in a fender but it happens!
Post by DanTreace » Sun Nov 07, 2021 8:40 am
Here is info from MTFCA Encyclopedia, that valve cover was painted engine color, black if black engine, and green if green engine (Moleskin). This is for late Improved cars with the Vaporizer carb set up.
27 brochure engine cropped close .jpg (23.95 KiB) Viewed 2122 times
First Name: Jeff
Last Name: Humble
Post by Humblej » Thu Nov 11, 2021 6:43 am
Found this picture of the 15 millionth model T. This one looks like Model A engine green and frankly this engine color is questionable since the body has been repainted the wrong color two different times, the engine could have been repainted at some time too.
