I just picked up a Stewart Magnetic Type 3. I’m trying to get the glass off, to clean behind it. How do I remove it.
Thanks in advance.
George
Unprr@cox.net
how to remove glass off stewart magnetic type 3178
Re: how to remove glass off stewart magnetic type 3178
The surrounding bezel is a slip interference fit. I tap around the edge with a screwdriver and drive it off.
Unprr
Topic author - Posts: 291
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Thanks Mark.
I will give it a try.
George
George
George, leave it face down and use a good penetrant around the rim to help. Gentle tapping will also helps to free it up. If you crack the glass the tapping was not gentle enough.
A soak in 10% pickling vinegar would help remove rust. I don't know what it would do to the dial face and odometer numerals.
