how to remove glass off stewart magnetic type 3178
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Post by Unprr » Wed Nov 03, 2021 8:05 pm
I just picked up a Stewart Magnetic Type 3. I’m trying to get the glass off, to clean behind it. How do I remove it.
Thanks in advance.
George
Unprr@cox.net
Re: how to remove glass off stewart magnetic type 3178
Post by Mark Gregush » Thu Nov 04, 2021 12:33 am
The surrounding bezel is a slip interference fit. I tap around the edge with a screwdriver and drive it off.
Unprr
Last Name: Schmidt
Post by Unprr » Thu Nov 04, 2021 2:54 pm
Thanks Mark.
I will give it a try.
George
Post by Allan » Fri Nov 05, 2021 1:43 am
George, leave it face down and use a good penetrant around the rim to help. Gentle tapping will also helps to free it up. If you crack the glass the tapping was not gentle enough. ;)
Post by TXGOAT2 » Fri Nov 05, 2021 1:25 pm
A soak in 10% pickling vinegar would help remove rust. I don't know what it would do to the dial face and odometer numerals.
