Size of bore in cam bearings holes in block??
Topic author - Posts: 5558
- Last Name: Hatch
Does anyone have the size for the front and center cam bearings holes in block?
Have not looked for it but was hoping someone had the Ford block drawing.
Another question, any idea why the cam bearings are not made in the oversized OD for worn block holes? At one time they were and that solved a lot of problems.
Who makes them now? I would be willing to buy a batch of front oversized. If they are on here please contact me at email address in pictures. Thanks Dan
Kerry
- Last Name: van Ekeren
Re: Size of bore in cam bearings holes in block??
Can't help with drawing specs but I know that the OD of the bearing is 1.371 and measuring a few blocks, they came in at 1.375. 1-3/8"
- Last Name: Hatch
I found a post of 1.371 to 1.373. If the is correct, 1.375 is worn.
That is why we need oversized cam bearings.
Thanks Dan
Thanks Dan
Kerry
If so Dan I find that interesting, anything usually on Fords basic machining was in whole fractions. The moving and replaceable parts had the clearances.
Can you lightly knurl the OD of replacement bearings to get a good fit?
Kerry
Pat, the bearing case is cast iron, I don't think knurling would work.
RGould1910
- Last Name: Gould
I've knurled them before.
- First Name: Henry
- Last Name: Lee
Shim stock!!!!!
Hank
Hank
Kerry
Henry, I pulled down an engine looking for a knock, turned out to be the cam bearings had been shimmed up with stock and had been flogged out over miles and time.
- First Name: Henry
- Last Name: Lee
You have to use tempered shim stock, should have mentioned that.., Oops!
Hank
Hank
- Last Name: Hatch
What we need are Oversized bearings. The front one is the one usually worn.
The person that use to make did that, but quit a few years ago.
Who is making these new bearings? Someone has to know them.
Kerry
There are other options, make your own or turn down the cast iron on an original and sleeve it.
- First Name: Henry
- Last Name: Lee
Like your option Frank!!!!!!!
