Painting Carb
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
Painting Carb
I am rebuilding a late NH carb. I plan to apply a prime coat and a black finish coat. What is the best way to apply, brush or rattle can? What is a good paint to use? I plan on using Rust-Oleum.
- Last Name: Patrick
Re: Painting Carb
Just use your best judgement… sometimes just wingin’ it is the best way to go…
Re: Painting Carb
In case you don't have rebuild instructions https://modeltfordfix.com/rebuilding-th ... el-t-ford/
I'd use Rust-Oleum Automotive Engine Paint is good enough for any heat concerns. Plug all holes see instructions on rebuild.
- First Name: George P
- Last Name: Clipner
Re: Painting Carb
I used engine paint, primer is already in it.
Re: Painting Carb
I don't paint them at all. That way it can't be attacked by fuel.
- Last Name: Burgett
Re: Painting Carb
Model airplane fuel proof dope works well. I use it on model A gas gauge numbers which are submerged in gas.
https://sigmfg.com/collections/covering ... dope-black
John
John
Re: Painting Carb
I've always used rattle can Rustoleum satin black. I dislike glossy paint on chassis parts. The Rustoleum doesn't need a primer.
Since this pictire was taken I've painted the filter. Same paint.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Re: Painting Carb
I use black lacquer in a spay can. Gas will not attack it. no primer.
- First Name: Mario
- Last Name: Brossard
Re: Painting Carb
I found this, but still hard to find a correct solution
https://spraygadgets.com/gas-resistant- ... Tank_Paint
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Morsher
Re: Painting Carb
I had a half dozen NOS carbs several years ago, and the bodies were probably black parkerized originally. Not sure what they called it way back then, but it was a rustproofing treatment that left the bodies with a dull blackish/gray finish. NEVER painted. This can be easily replicated if you check on line, lots of easy methods. This all if you want original look. Otherwise, paint away
Re: Painting Carb
Rust-Oleum Engine Enamel Spray Paint is a high temperature engine paint protects your engine from the harmful effect of heat, oil, gas, grease, rust, salt, solvents, and humidity. It is made for manufactured for the cars’, bikes’ as well as other automotive engines. Rust Oleum Engine Enamel Spray resists high-heat up to 260°C and gives a smooth finish to your engine surface. This forms a long-lasting coating that keeps out chipping and peeling offering an enduring finish. Interestingly, a single spray can is well-enough to paint 10-12 sq.ft of an area.
Available at automotive stores everywhere -
- First Name: Mario
Re: Painting Carb
Hi, I used personnaly an electric Paint Sprayer which is cheap and work really well. I used for Engine Enamel paint or personal use at home.
The one I used cost me only $67 in Canadian dollars on Amazon. It may cost ONLY $46 US$ and you can choose the paint you like.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Jay
- Last Name: Couture
Re: Painting Carb
I used TopFlite fuel resistant model airplane paint from a local hobby shop. It is the only thing I have found that has survived the toxic Minnesota gas formula. My Model A carb has lasted 8 years, still solid. The Rustoleum on the engine pan underneath turned to goop long ago.
