Engine pan hardware?
Post by Steve Jelf » Thu Aug 01, 2019 3:45 pm
We don't need to get into a big whooptedoo about whether to use engine pans. I aim to do it. But in researching the mounting hardware I find some disagreement about what's the right hardware. I'm sure about the bolts: ¼-20 carriage bolts with about an inch of thread. But what about the nuts? Hex or square? What kind of washers, if any?
Adam
First Name: Adam
Last Name: Doleshal
Re: Engine pan hardware?
Post by Adam » Thu Aug 01, 2019 4:27 pm
Long skinny carriage bolts that go thru the hood shelf, frame rails, splash pan with a lock washer and square nut on the bottom.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Aug 01, 2019 6:58 pm
Steve-
Take a look here:
http://www.cimorelli.com/mtdl/1915/default.htm
P/N 3088 is engine pan bolt 09-12 uses 7 of them. 1/4" x 9/16" I believe they were 28 tpi and have square heads bolts drilled for cotter pins.
Yet used square nuts. (!)
P/N 3088B is engine pan and hood board bolt and nut '09-'15 1/4" x 3-1/4" (short) (2 req)
P/N 3088C is engine pan and hood board bolt and nut '09-'15 1/4" x 3-5/8" (size) (? req)
I wish I could be more help. Maybe someone has some pics of original "engine dust shields," bolts, and nuts.
Keith
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Thu Aug 01, 2019 8:20 pm
The long bolts that Adam mentions were a combination hood board and engine pan bolt, in a carriage bolt configuration, that began to be used about July of 1913. They came in "short" (3-1/4", used in front) and "long" (3-5/8", used in the rear) lengths. Until then, the (separate) hood board bolts were a slotted carriage bolt 1-5/16" long, and the seven 1/4" x 28 engine pan bolts were as shown in Keith's photo, and were 25/32" long.
Post by Allan » Fri Aug 02, 2019 6:05 am
Our Canadian sourced cars had bolts as RV advised. The same bolts that hold the hood shelves on, hold the engine pans too. i don't know if this is universal or not, but the heads of these bolts are smaller than standard hardware store coach bolts, and the SQUARE nuts are somewhat larger.
Post by Original Smith » Fri Aug 02, 2019 10:32 am
Here again, how are we supposed to supply and answer, when the year of the car is not given? Those items were changed over the years considerably. We all should agree that the engine side of the engine pans use the engine bolts. In many cases the engine pans have gotten the holes enlarged due to being replaced several times, and require a flat washer to hold them on. In 1913 alone the hood board bolts were changed twice! The first design is like a 1912, with a slotted head that is fastened under the top side of the frame. The second design is still slotted, but goes through to the bottom edge of the frame, and is held on by 1/4-20 square nuts, 1/2" across the flats. There are two different lengths of these on all years from March of 1913 until the end. The later T's use carriage bolts, with very small heads, much smaller than the hardware store variety, but still use the same 1/4-20 square nuts, 1/2" across the flats.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Aug 02, 2019 10:53 am
FWIW, the change in 1913 that Larry mentions took place right at the end of the model year, in late June/early July.
Post by Steve Jelf » Fri Aug 02, 2019 11:01 am
Yes, I should have specified 1915. Not telling the year is one of my pet peeves, so shame on me. :)
Post by Allan » Fri Aug 02, 2019 9:42 pm
Steve, some of us realised you had no T later than 1915, and the early stuff did not apply in your case. At least, that's my story and I'm sticking to it!
tmagill
Last Name: Magill
Post by tmagill » Sat Aug 03, 2019 1:23 pm
Keith, what are the clamps in your picture for? Tim
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Aug 04, 2019 1:15 am
The clamps are for acetylene headlamp gas lines.
tmagill
Last Name: Magill
Post by tmagill » Sun Aug 04, 2019 3:52 pm
Keith do you make them or have any for sale? I need one for a 1914. Thanks Tim
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Aug 06, 2019 1:12 pm
No, I don't but they are not too difficult to make.
I don't remember the exact dimensions, but for my 1911 they are about 1/2" wide, and 1-3/4" long with a 1/4" loop in the end.
One link below has Rich Eagle's specifications. I recently learned that the photo I posted is his.
There is some more information here:
http://www.mtfca.com/discus/messages/506218/540853.html
http://www.mtfca.com/discus/messages/33 ... 1371823897
http://www.mtfca.com/discus/messages/50 ... 1436287370
tmagill
Last Name: Magill
Post by tmagill » Tue Aug 06, 2019 5:08 pm
Thanks Keith for the info. Tim
Tbird
Last Name: Bird
Post by Tbird » Fri Mar 25, 2022 5:47 pm
I'm resurrecting this post because I have a question as to the length of the earlier style engine pan hardware with the square heads. I'm making my own bolts and ned to know the actual length from under the head to the end of the bolt. I saw two dimensions posted 9/16 and 25/32. Can anyone with the hardware give a dimension from under the head to the end of the bolt?
Mike
Post by Steve Jelf » Fri Mar 25, 2022 9:56 pm
This list claims they're the same, 1909-1927.
Bolts_nuts_threaded_items.pdf
(129.63 KiB) Downloaded 124 times
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Sat Mar 26, 2022 9:23 am
Hello Mike:
I too made my own square head bolts, and built to the lengths shown here. I put the cotter pin holes as close to the ends of the screws as I could get.. Parts are a tight fit, but they do fit. I can imagine that repro gas line clamps of incorrect heavier gauge, could be a watch out here.
Regards,
Scott
Post by TRDxB2 » Sat Mar 26, 2022 10:37 am
I am with Larry on this. The FORUM is the classroom for all current and future members. It needs to be the place that "documents" authentic and non-authentic parts and solutions. Not everybody knows what everybody owns and if they own more than one which one is up for discussion, or if they are just helping out a friend. Good descriptions and solutions, with pictures should be provided whenever possible.
