Pressurized Oil System Component Choices/Options
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Thu Apr 14, 2022 8:56 am
Working on a full pressure oil setup on a T engine. Looking for recommendations/sources/options on: adjustable pressure relief valve (bypass), check valve, remote oil filter adapter and oil pickup/screen. Dan McEachern makes a neat remote oil filter adapter with an adjustable relief valve, but he is struggling with getting castings from his vendor, looking for options in the event the situation continues. Thanks
Les Schubert
First Name: Les
Last Name: Schubert
Re: Pressurized Oil System Component Choices/Options
Post by Les Schubert » Thu Apr 14, 2022 9:47 am
Where are you locating the oil pickup. This is a important factor in deciding what type is suitable.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Apr 14, 2022 9:49 am
How hidden and/or period correct do you want it to be...?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Apr 14, 2022 9:58 am
Speedway Automotive sell oil filter adapters for remote installation. Another option is the filter adapter for Ford FE engines (352,390,428) and bolt then to the pan.
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Thu Apr 14, 2022 10:10 am
I'm running a deep sump pan. That's where I'll locate the pickup. Good question about appearance (period correct). I'm looking for exactly the opposite, billet aluminum and stainless braided lines will be OK. Thanks
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Apr 14, 2022 10:18 am
The Datsun pump has proven reliable for me...
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Apr 14, 2022 11:46 am
The plug at the top is for priming
Datsun B210 pump
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Thu Apr 14, 2022 1:20 pm
Should have mentioned that I'm running a VW pump from the cam. The idea remote filter bracket would have multiple outlets (2) one for the bearing supply and another for a pressure relief valve as well as a smaller port for a gauge or pressure switch. Thanks
