Pressurized Oil System Component Choices/Options
henryford2
Topic author - Posts: 831
- First Name: Joseph
- Last Name: Andulics
Working on a full pressure oil setup on a T engine. Looking for recommendations/sources/options on: adjustable pressure relief valve (bypass), check valve, remote oil filter adapter and oil pickup/screen. Dan McEachern makes a neat remote oil filter adapter with an adjustable relief valve, but he is struggling with getting castings from his vendor, looking for options in the event the situation continues. Thanks
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Pressurized Oil System Component Choices/Options
Where are you locating the oil pickup. This is a important factor in deciding what type is suitable.
Kevin Pharis
- Last Name: Pharis
How hidden and/or period correct do you want it to be...?
Les Schubert
- First Name: Les
Speedway Automotive sell oil filter adapters for remote installation. Another option is the filter adapter for Ford FE engines (352,390,428) and bolt then to the pan.
henryford2
I'm running a deep sump pan. That's where I'll locate the pickup. Good question about appearance (period correct). I'm looking for exactly the opposite, billet aluminum and stainless braided lines will be OK. Thanks
Kevin Pharis
- Last Name: Pharis
The Datsun pump has proven reliable for me...
Les Schubert
- First Name: Les
The plug at the top is for priming
Datsun B210 pump
Datsun B210 pump
henryford2
Should have mentioned that I'm running a VW pump from the cam. The idea remote filter bracket would have multiple outlets (2) one for the bearing supply and another for a pressure relief valve as well as a smaller port for a gauge or pressure switch. Thanks
