hand crank coil tester
				Philip
- First Name: Philip
- Last Name: Thompson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Here are some pics of my hcct. It was given to
Me in pieces by a fellow club member who
Scored a factory made one. I redid some of the
Frame and re wound 3 of the coils using masking
Tape. It is made by the plans that are on the
Board. It works great now I need a meter.
Philip
Philip
				Philip
Re: hand crank coil tester
Click the pics and they go right side up?
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
The type of meter that is used on the HCCT is an Iron Vane type, AC Ammeter.
Rectifier type AC Ammeters won't read correctly.
I have tested a couple of the low cost Iron Vane Ammeters from China.
I found them to be inaccurate.
Respectfully Submitted,
Be_Zero_Be
						Be_Zero_Be
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
try this one, not from china or Russia.
https://www.ebay.com/itm/Simpson-17668- ... SwH4hbIYSI
goodluck
andre
belgium
goodluck
andre
belgium
BE_ZERO_BE
- First Name: BOB
Simpson is a great meter.
This on is 0-5 Amps AC.
The 1.3 Amp point is less than 1/4 of the scales deflection.
It can be difficult to see the 1.2 - 1.4 Range on this meter.
The perfect HCCT meter is 0-2 Amps AC.
Be_Zero_Be
						Be_Zero_Be
BE_ZERO_BE
- First Name: BOB
This is the meter you want.
https://www.ebay.com/itm/Vintage-Weston ... SwG7Ncq85k
Be_Zero_Be
						Be_Zero_Be
Les Burg
- First Name: Les
- Last Name: Burg
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
Philp, I have an original Weston form a Ford HCCT that I know nothing about. The scale plate is out of it but the movement is free. I understand there is a member that restores and calibrates them. you can PM me if you like.
Les Burg
[image][/image]
						Les Burg
[image][/image]
thom
- First Name: Tommy
- Last Name: Coffey
- * REQUIRED* Type and Year of Model Ts owned: '21 Touring
I picked up a spare flywheel and magneto for our '21 Touring some time back. I plan to build a frame and make a coil tester. I have not yet bought the meter to complete it.
MKossor
- First Name: Mike
- Last Name: Kossor
Philip, FYI, nice HCCT meter available in the classifieds right now.  viewtopic.php?f=5&t=2946
Good luck with your vintage coil tester project.
