Material for inside body panels
Topic author - Posts: 116
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
Getting along on some of my "projects" and wanting to start on the part I have been avoiding, the interior. I am trying to figure out what material to use to make the inside panels. It appears to be a non-corrugated card board painted black on the open cars and cloth covered on the closed cars. I have been nosing around trying to find something remotely close as I have an open and closed car to do. Everything I come across is either too stiff or too flimsy. Any suggestions of what to use and where to get it? Thanks for any advice.
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
John
Martin, Ohio
- Last Name: Strange
Re: Material for inside body panels
The vendors sell kits if you want to go that route. Call before you order to make sure they actually have the items you want in stock - unless you want to be put on an excruciatingly long wait list.
If you are determined to do it yourself, here are a couple of guys who did their own interiors from scratch:
https://www.youtube.com/watch?v=Su3J6t1C5oI
https://www.youtube.com/watch?v=qFyklhAnxx8
3mm MDF does the job nicely. It is easy to work, but does need sealing against moisture. It can even be sewn through by a decent sewing machine if you need to stitch covering over it.
- First Name: Joseph
- Last Name: M
I had bought Door Panel Material from Restoration Specialties, you can find a link to their catalog through the link below:
https://www.restorationspecialties.com/
It is on page 117 of their PDF catalog. It is a black, waterproof material, 3/32" thick and closely resembles the original cardboard material that started in 1917. The sheets are relatively cheap, but shipping is expensive (oversize), but you can ask them to cut the sheets so the shipping will be less. I would recommend the original style binding/welt to trim out the edges of the panels once installed, it looks nicer:
https://www.modeltford.com/item/D-TRIMOR.aspx
- Last Name: Morsher
John, if you have any decent upholstery shop nearly, it’s called cowl board. It’s treated to hold up well in an auto. A decent machine can sew through it, also. I need to run up town and get a couple sheets myself, so if you cannot find it, let me know size needed. It’ll be a lot cheaper than sending to California for it. Tmorsher@icloud.com
- Last Name: Pharis
You can also order up 1/16” ABS sheet as an option. Glues, cuts, and sews with all the usual tools required. It holds a formed shape with a touch of heat, and won’t be bothered by getting wet
- Last Name: M
Restoration Supply is in California, Restoration Specialties is in Pennsylvania.
Thanks Pep, yes I missed that. Indeed, it is very close to what was used originally.
