Approximate Year Of This Model T?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Mon Sep 19, 2022 3:34 pm
Taken out in the Big Bend area of Texas. Looks to be a three window top. What is the approx. year of this Model T? Thanks….
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: Approximate Year Of This Model T?
Post by Fire_chief » Mon Sep 19, 2022 3:46 pm
Three window openings in the rear of the top indicates it is '17 to '22.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Mon Sep 19, 2022 7:17 pm
Is it just the lighting, or is that a brass radiator?
Post by TRDxB2 » Mon Sep 19, 2022 8:47 pm
This should help
3 windows & Brass radiator
what t.png (165.37 KiB) Viewed 3101 times
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Tue Sep 20, 2022 8:05 am
Perhaps you could get a clearer copy of that photo if you contacted these guys?
https://marfamuseum.org/2019/09/05/duncan/
They probably have a few other interesting photos with Model Ts.
Last Name: Wrenn
Post by TWrenn » Tue Sep 20, 2022 8:47 am
This should help
Brass radiator cars had the "crown" rear window, not 3 small windows. May be lighting, may be a replacement top put on an earlier car? Pic just isn't clear enough.
Post by Wayne Sheldon » Tue Sep 20, 2022 8:32 pm
Just not clear enough detail.
The front fenders could appear to be flat? Could be 1915/'16 with a brass radiator? Or not. I wouldn't go from the shiny top of the radiator however. The shiny area appears too rectangular. I suspect that is a license plate hanging on a radiator neck bracket. I like the era accessory brackets myself, but do not like the way they look on cars. So I have never used one.
Tops were sometimes replaced by later style replacements, putting the three windows on late brass model Ts.
A 1913ish pickup,
A 1914 touring with later headlamps and top rear curtain.
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Thu Sep 22, 2022 5:46 pm
A slightly clearer crop from Terry at the museum.
Last edited by John E. Guitar on Thu Sep 22, 2022 8:25 pm, edited 1 time in total.
Post by Wayne Sheldon » Thu Sep 22, 2022 7:16 pm
Wow! So much better to work from an unadulterated early generation copy! Thanks J E G !
Without the colorization and digital manipulation, it can clearly be seen as a brass era radiator! No high mounted license plate. I can almost make out the "Ford" script on the radiator, and a small dogbone cap without a Moto-Meter.
Without brass rims on the lamps, likely a late 1915 or 1916 with a later style top installed as a replacement.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Sep 22, 2022 7:16 pm
Thanks John 😊
Post by TRDxB2 » Fri Sep 23, 2022 11:24 am
A little better
0112_good roads near marfa2.jpg (70.11 KiB) Viewed 2659 times
Post by Rich Eagle » Fri Sep 23, 2022 11:29 am
the 3-window rear curtain was 1917-Mid 1922.
