Approximate Year Of This Model T?
MichaelPawelek
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: Approximate Year Of This Model T?
Three window openings in the rear of the top indicates it is '17 to '22.
- First Name: Austin
- Last Name: Farmer
Is it just the lighting, or is that a brass radiator?
This should help
3 windows & Brass radiator
- Attachments
- what t.png (165.37 KiB) Viewed 3107 times
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Perhaps you could get a clearer copy of that photo if you contacted these guys?
https://marfamuseum.org/2019/09/05/duncan/
They probably have a few other interesting photos with Model Ts.
Just not clear enough detail.
The front fenders could appear to be flat? Could be 1915/'16 with a brass radiator? Or not. I wouldn't go from the shiny top of the radiator however. The shiny area appears too rectangular. I suspect that is a license plate hanging on a radiator neck bracket. I like the era accessory brackets myself, but do not like the way they look on cars. So I have never used one.
Tops were sometimes replaced by later style replacements, putting the three windows on late brass model Ts.
A 1913ish pickup,
A 1914 touring with later headlamps and top rear curtain.
A 1913ish pickup,
John E. Guitar
- Last Name: Guitar
Last edited by John E. Guitar on Thu Sep 22, 2022 8:25 pm, edited 1 time in total.
Wow! So much better to work from an unadulterated early generation copy! Thanks J E G !
Without the colorization and digital manipulation, it can clearly be seen as a brass era radiator! No high mounted license plate. I can almost make out the "Ford" script on the radiator, and a small dogbone cap without a Moto-Meter.
Without brass rims on the lamps, likely a late 1915 or 1916 with a later style top installed as a replacement.
Moxie26
- Last Name: Jablonski
Thanks John
A little better
- Attachments
- 0112_good roads near marfa2.jpg (70.11 KiB) Viewed 2665 times
the 3-window rear curtain was 1917-Mid 1922.
