Where to buy extra large head carriage bolt
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Sun Oct 30, 2022 12:01 am
I am working on my Martin Perry project. It is missing a few of these. Anyone have a suggestion where I can find a replacement?
Thanks!
Matt
Re: Where to buy extra large head carriage bolt
Post by Allan » Sun Oct 30, 2022 12:23 am
Matt, I have restored to bronze welding a washer under the bolt head and dressing them down to suit. Works ok if you only need one or two.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sun Oct 30, 2022 12:27 am
You might try looking at elevator bolts. They are pretty close to what you are looking for, but they seem to vary by the manufacturer, the head profile differs a bit (from manufacturer to manufacturer). I needed some when attaching a Kari-Keen trunk to my Model A.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Oct 30, 2022 12:28 am
Do a search for "step bolts".
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Oct 30, 2022 12:30 am
Call Dave at the garage on Monday. We have several sizes in stock if you can't find any elsewhere. (951) 735-4791
Post by TRDxB2 » Sun Oct 30, 2022 2:34 am
Try Grainger - & its step bolts that have the wider head
https://www.grainger.com/category/faste ... step-bolts
There are also Timber bolts but harder to find
They are different as the underside is not square https://www.portlandbolt.com/products/bolts/timber/
Post by John kuehn » Sun Oct 30, 2022 8:17 am
I’ve seen them at the larger Ace hardware stores.
Post by RajoRacer » Sun Oct 30, 2022 11:25 am
What size you needing Matt ?
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Oct 30, 2022 12:14 pm
I would agree the STEP BOLTS are closer in appearance to the original. All the ELEVATOR BOLTS that I have seen used on conveyor equipment in grain elevators, have a large diameter head, but they are flat and not 'domed'.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Oct 30, 2022 12:16 pm
I used elevator bolts. Turned down on my lathe to the shape I wanted to match for the 8in1 truck body. I was ably to located the bolt
s for the MP cab from old salvaged hardware I had collected and friends collections.
Don
First Name: Don
Last Name: Azevedo
* REQUIRED* Type and Year of Model Ts owned: 5
Board Member Since: 2003
Post by Don » Sun Oct 30, 2022 1:59 pm
Do you need 5/16" or 3/8" step bolts? How many do you need? I may be able to help.
Don
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Sun Oct 30, 2022 5:09 pm
Wow I appreciate all the offers for help!
I started at Ace Hardware and asked the staff a while back and they said they didn’t have those. I recently met the “bolt guy” that actually stocks the bolts for all the stores he also confirmed that they don’t carry it. The guy actually mentioned that I could try other locations that may have old stock.
The project is stored offsite but here are two bolts (in top of photo) that I took off. I believe they were both used to hold a fender bracket. One has a square that you normally find under a carriage bowl. The other one barely has a rib. Is that a timber bolt? In any case one of them must’ve been replaced. Does anyone know what Martin Perry originally used?
The originals were cut off by a previous owner. I happen to have one bolt that would work as a replacement. It is 2 1/4 inches long and 5/16 diameter.
Thanks!
Matt
Post by Scott_Conger » Sun Oct 30, 2022 5:27 pm
Post by John kuehn » Sun Oct 30, 2022 5:37 pm
Amazon has all kinds of step bolts.
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Sun Oct 30, 2022 11:18 pm
Check out Blacksmith Bolt as well. https://www.blacksmithbolt.com/ I use them for proper milled wood screws in my pump organ repairs.
