Where to buy extra large head carriage bolt
Matt in California
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
I am working on my Martin Perry project. It is missing a few of these. Anyone have a suggestion where I can find a replacement?
Thanks!
Matt
						Thanks!
Matt
Re: Where to buy extra large head carriage bolt
Matt, I have restored to bronze welding a washer under the bolt head and dressing them down to suit. Works ok if you only need one or two.
Pep C Strebeck
- First Name: Joseph
- Last Name: M
You might try looking at elevator bolts. They are pretty close to what you are looking for, but they seem to vary by the manufacturer, the head profile differs a bit (from manufacturer to manufacturer). I needed some when attaching a Kari-Keen trunk to my Model A.
Mark Chaffin
- Last Name: Chaffin
Do a search for "step bolts".
Mark Chaffin
Call Dave at the garage on Monday.  We have several sizes in stock if you can't find any elsewhere.  (951) 735-4791
Try Grainger  - & its step bolts that have the wider head
https://www.grainger.com/category/faste ... step-bolts
There are also Timber bolts but harder to find
They are different as the underside is not square https://www.portlandbolt.com/products/bolts/timber/
I’ve seen them at the larger Ace hardware stores.
What size you needing Matt ?
				ModelTWoods
- First Name: Terry
- Last Name: Woods
I would agree the STEP BOLTS are closer in appearance to the original. All the ELEVATOR BOLTS that I have seen used on conveyor equipment in grain elevators, have a large diameter head, but they are flat and not 'domed'.
- First Name: Dallas
- Last Name: Landers
I used elevator bolts. Turned down on my lathe to the shape I wanted to match for the 8in1 truck body. I was ably to located the bolts for the MP cab from old salvaged hardware I had collected and friends collections.
				Don
- First Name: Don
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 5
- Board Member Since: 2003
Do you need 5/16" or 3/8" step bolts?  How many do you need?  I may be able to help.
Don
						Don
Matt in California
- First Name: Matt
- Last Name: G
Wow I appreciate all the offers for help!
I started at Ace Hardware and asked the staff a while back and they said they didn’t have those. I recently met the “bolt guy” that actually stocks the bolts for all the stores he also confirmed that they don’t carry it. The guy actually mentioned that I could try other locations that may have old stock.
The project is stored offsite but here are two bolts (in top of photo) that I took off. I believe they were both used to hold a fender bracket. One has a square that you normally find under a carriage bowl. The other one barely has a rib. Is that a timber bolt? In any case one of them must’ve been replaced. Does anyone know what Martin Perry originally used? The originals were cut off by a previous owner. I happen to have one bolt that would work as a replacement. It is 2 1/4 inches long and 5/16 diameter.
Thanks!
Matt
Thanks!
Matt
Amazon has all kinds of step bolts.
BuddyTheRoadster
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Check out Blacksmith Bolt as well. https://www.blacksmithbolt.com/ I use them for proper milled wood screws in my pump organ repairs.
