can I use a Z head on a 23 with a low radiator?
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Mon Nov 14, 2022 4:43 pm
What is the fix for the upper water neck? I don't think a hose will bend like that. Will a water neck for a high radiator work?
Kerry
Last Name: van Ekeren
Re: can I use a Z head on a 23 with a low radiator?
Post by Kerry » Mon Nov 14, 2022 5:26 pm
The only thing you will have to check is that the pistons clear the head at TDC other than that it is all the same for the top hose and radiator to bolt together.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Nov 14, 2022 5:39 pm
Don’t get the low head and high head mixed up with the low radiator and high radiator. The Z head is a high head and takes the head outlet to radiator used 1917-1925. It sounds like you may have a head outlet for a brass radiator car, the correct outlet should go up aprox 90 deg from the head not up at aprox 45 deg from head.
Post by TRDxB2 » Mon Nov 14, 2022 5:51 pm
Pictures of what the question is about always helps. Can't assume "stock"radiators, water outlets in a 100 yr old car
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Mon Nov 14, 2022 5:55 pm
I have a low radiator, I want to use a high z head. Can I use a later outlet to make the radiator hose align better is the question.
First Name: john
Last Name: karvaly
Post by speedytinc » Mon Nov 14, 2022 6:19 pm
Yes. the Z head directly replaces the stock iron head you should have. The water outlet is the same from 17-25.
If you dont have a Z head already, I would highly recommend you go with the Prus head instead.
Kerry
Post by Kerry » Mon Nov 14, 2022 6:20 pm
The radiator makes no difference, your engine if stock would have a high head and the Z is the same.
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Mon Nov 14, 2022 7:14 pm
In case I’m not explaining good enough
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Mon Nov 14, 2022 7:29 pm
Never mind, the later neck will make it work
Kerry
Post by Kerry » Mon Nov 14, 2022 8:07 pm
Yes, that outlet is off a low head up to about 1917
Post by Allan » Mon Nov 14, 2022 11:41 pm
When fitting a Z head be sure to check clearance around the pistons. Before fitting it, clean out all threads in the block. Check your head bolts in the head for length. Because you need a washer under the bolt heads, effective length of the bolts is reduced, and you are more likely to strip a thread in the block. I use new, longer bolts to get maximum thread engagement.
I too suggest a Prus head if you haven' already bought a Z head.
Hope this helps.
