I was studying a “vintage welding book “
I thought people might find this “interesting/amusing “
I haven’t personally tried it.
Hardening valve stems!
Les Schubert
Topic author - Posts: 1364
- First Name: Les
- Last Name: Schubert
Re: Hardening valve stems!
How many people stretched a valve?
I have seen pictures & descriptions of valve stems being heated above the guide area & pulled to lengthen.
How did the head get squared back up to the stem?
David Greenlees
- Last Name: Greenlees
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Les, thanks for posting this. Is it possible the valve would need to be water-hardening steel for it to work? Lot's of left over used valves here in the engine shop, I'll try it soon.
Les Schubert
- First Name: Les
David
Just something I found in a “vintage “ welding book. Most steel will harden when quenched like this.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Les,
There's a quite detailed paper on valve cooling here:
https://fredstarr.com/wp-content/upload ... ooling.pdf
It's not related to your post but I think you would find it interesting.
Fred Starr (retired UK metallurgist) has written a few other papers on the history of valves that are worth tracking down.
Philip
- First Name: Philip
- Last Name: Thompson
i would rather have the valve wear than the lifter
