Need info regarding '11 Torpedo top strap attachment point at front of car
Post by Scott_Conger » Thu May 16, 2019 6:29 pm
I would appreciate a picture or description of the securing device that '09-'12 top straps attached to at the front of the frame. Thank you very much.
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Re: Need info regarding '11 Torpedo top strap attachment point at front of car
Post by John iaccino » Thu May 16, 2019 6:37 pm
Scott, the top straps can be attached by one of two ways. Either get the figure 8 loops and fasten them to the radiator bolts and then your top straps would fasten to them. The other way is like my '11. My fender irons have loops incorporated in them to fasten the top straps to.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat May 18, 2019 10:47 pm
Mine are like John's
Here is the loop on the fender iron:
Here is the hook:
I don't have a pic of the brass plated steel twisted figure 8 loop, but it mounts on the side of the frame with the fender iron bolt.
https://www.modeltford.com/item/3924AS.aspx
https://www.modeltford.com/item/3924SL.aspx
Post by Scott_Conger » Sat May 18, 2019 10:57 pm
Keith
so good of you to respond and provide pictures! Many thanks for your info and effort.
I have since found that both front fender irons have 1 long and 1 short bolt holding them on...at first I thought it was sloppy work from the past, which it sort of is, as one bolt on one side is the front-most bolt and is the rear-most bolt on the other side...
I now realize that the long bolt likely held a figure-8 tab and that is what I intend to use. At the present time, the straps are held with somewhat crude brackets affixed to the radiator stud...I know that this is a version of "correct", but believe the evidence in front of me speaks to a frame-mounted figure 8 loop.
Many thanks again and regards to you and all responders...I have what I need now!
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun May 19, 2019 1:27 am
Scott-
Here is an image of a twisted figure 8 type:
Keith
Post by Scott_Conger » Sun May 19, 2019 10:00 am
Thanks again Keith!
and thanks to MTFCA for a terrific forum
