Exhaust manifold question
Boaski
Topic author - Posts: 56
- First Name: Todd
- Last Name: Retterer
My T has an exhaust manifold that appears to be for an auxiliary heater:
The shroud is missing and there are no holes in the floor to duct the heat if the shroud was there. My question is: are there any advantages or disadvantages of running this exhaust manifold? I know it seems to radiate heat rather well under the hood.
- Last Name: Tannehill
Re: Exhaust manifold question
One aff do vantage is you can easily build the cover to make it work for winter driving
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
The heater manifolds are usually pretty straight, and do not warp like the standard manifold.
1922 Coupe , 1926 Touring
Like he said, they don't warp- big advantage
Heater shroud -- -- --
It may lend itself well to a custom-made manifold cooker.
Boaski
- First Name: Todd
Thanks for the responses. I guess I'll keep it on there if the stock ones are more prone to warping. Does the little "A" cast into the manifold mean it' an Arvin?
I noticed my intake was a little frosty looking on hot, high humidity days. I think I'll have to rig up an inlet pipe somehow.
GG Gregory
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Have one like it on my 27 Roadster, and a good spare if I ever need it !
1922ford
- First Name: Tom
- Last Name: Bauer
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring 1924 roadster 1925 coupe
- Board Member Since: 2012
Our ’22 touring has the same exhaust manifold as yours has. The comments are correct about it being unlikely to warp. It’s a good unit to have.
The carb and intake manifold on the touring routinely iced up from moderately to seriously. There seems to be no heat pipe (or stove) available for the exhaust manifolds we have, so I cobbled one up using an old heat pipe that had seen its better days. As you can see I also incorporated the lid off of a metal can. It was a cut, fit, and try job. It isn’t pretty but has been on the job since 1999.
I hope the photo show how I fashioned a heat pipe and if you have any questions I’d be glad to try and answer them.
Good luck. Tom in Taylor Mill, KY 41015
Boaski
- First Name: Todd
Thanks for posting the picture. That gives me an idea of what to make.
White Auto used to sell Arvin branded stuff. I once had an Arvin 6-tube table radio.
