Ideas for a column throttle and foot-feed combination (Pre-1926)
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1921 Coupe, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Sun Dec 03, 2023 1:53 pm
What are the different ways of making a combination throttle control on a Model T? I'm looking for one that uses the standard lever on the steering column and also a foot-feed on a pre-1926 engine with the standard NH carb. A System that gives you the same combination as a model A. I've got one idea of how to do it but there may be better/simpler versions out there . . . no sense re-inventing the wheel.
Preserving Mechanical History for Future Generations since 1965
Re: Ideas for a column throttle and foot-feed combination (Pre-1926)
Post by TRDxB2 » Sun Dec 03, 2023 3:41 pm
There were accessory kits available from the suppliers years back, besides back when.
Gas Pedal.jpg (88.81 KiB) Viewed 1214 times
Gas Pedal instructions 2.jpg (78.57 KiB) Viewed 1214 times
More ideas
this uses the Vaporizer to Holley carb linkage as part of the design
Using the Vaporizer Throtlle Linkage requires that you also need to have the Conversion linkage for the Vaporizer to Holley NH kit
https://www.mtfca.com/discus/messages/1 ... 1276459118
https://www.mtfca.com/discus/messages/8 ... 1245269322
Link to this option https://www.mtfca.com/discus/messages/1 ... 1299819284
the peddle part is still sold by some suppliers https://www.macsautoparts.com/1928-31-f ... 939-1.html
https://www.mtfca.com/discus/messages/2 ... 29461.html
The Model A (1928-29) design can also work - put not there parts.
jsaylor
Last Name: Saylor
Post by jsaylor » Mon Dec 04, 2023 12:42 pm
Texas T Parts used to sell one that works well. I bought one before Bird Haven bought them out and it disappeared. It would be easy to duplicate.
TTP Foot Throttle.pdf
(151.13 KiB) Downloaded 142 times
Post by TRDxB2 » Mon Dec 04, 2023 12:51 pm
Thanks for the pictures & instructions. I have one that I was thinking of using, now its a no brainier.
Post by TRDxB2 » Mon Dec 04, 2023 1:18 pm
I found this for a Winfield down draft carb on a Model A. Very simple set up. The arm on the carb is a modern part sold by Speedway etc
Model A (28-29) has a bracket that attached to hogs head ears (bracket doesn't fit a Model T nut one could be made and then the rest added .
The arm on the left is attached to the throttle rod (need to find picture) and the arm on the left is hooked up to the carburetor (need picture)
