TT driveshaft coupler help
KenHaverhill
Topic author - Posts: 109
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Are there any differences in the coupler to connect a TT rear end to the driveshaft? We had a coupler in a working snowmobile with a ruxstell and Watford come apart .we had a spare stock rear end so we took the coupler off of it but it won't fit? Splines seem off.splines on rear end drive gear could have a twist I guess but look ok
Adam
- First Name: Adam
- Last Name: Doleshal
Re: TT driveshaft coupler help
There are 3 different splines for the worm gear / coupling / drive shaft and they don’t interchange; Early TT, Late TT, & Model A
KenHaverhill
Thanks for the info Adam
Adam
- First Name: Adam
Here are specifics on the TT variations:
1920:
Then, by 1924, they realize the mis-match causes problems and tell you not to do it!
1924:
The couplers began to be “marked” late 1924…
Later in 1924:
1920:
1924:
Later in 1924:
